4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: Jporch316
Re: Sky puck activation code
@RachelHadley wrote:
Followed set up on scream. Now have an activation code but have no clue where to go to activate as the sky.com/activate just comes up with an 'Oops something went wrong' message. H E L P!!!!!
This seems to be an ongoing issue and could be caused by several issues
- not logged into your sky id account before navigating to the activation page
- having multiple sky ID s (mobile and tv) and using the wrong account to sign in
- having an older sky ID following a cancellation etc and sky s backend system not recognising the new one
the last of these issues will require a phone call to sky and often you can tell if this is the case if you have no access to billing information in your MySky app
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Avatar for GD1
Level 16 icon
Re: Sky Glass and Stream Pucks - Won’t load the home screen beyond a blue refresh screen
@ClareP123  I have merged your post to this existing thread that is discussing the ongoing issue, you added this to an older thread that is unrelated to the outage on Fiday.
Have you tried the steps in post 2 of this thread, which is different from the normal reboot. If so how far have you gotten with it?
@ClareP123 wrote:
I've tried the reset/recovery process multiple times and it's still not working. It's been out since Friday!
Where is it going wrong ?
This message was authored by: ClareP123
After trying the recovery process for the 4/5th time, I now have scenic pictures on my screen.
no instructions to reboot, and regardless of what button I press on the remote, nothing happens
This message was authored by: Gemma411
Hi my sky puck hasn’t worked for 3 days I’ve tried everything suggested any ideas ?
Hi my sky puck hasn't worked for 3 days I've tried everything and can't get through to them on the phone any ideas ? Thanks
This message was authored by: Mrs+Kennedy
Re: Sky Stream Puck stuck on PIN reset
My pin incorrect if been trying for two days thought I'd sorted it after resetting the puck everything fine then I get to the pin back to 0-3 goes try changing pin do as instructions says and then incorrect geez nightmare
Re: Sky Stream still not working......
@Kirsty7777 wrote:
Hi, yes I have followed the steps carefully for sky glass downstairs and sky stream upstairs, sky glass is now working but sky stream is stuck on the page where it asks to hold the 4 and 6 numbers together for 2 seconds on the remote. This is not doing anything at all, my remote has new batteries and Is working fine too, I cannot get past this step. Thanks.
@Kirsty7777  I don't know if this will work but it is worth a try.  Pressing 4 & 6 for 3 seconds (2 insn't long enopugh IMHO) will put the remote into IR mode so the suggestion from @horace may work for you but if not try pressing 1 & 3 for 3 seconds instead.  This will put the remote into bluetooth mode.
This message was authored by: Kirsty7777
Re: Sky Glass Power up Issues 19-9-24
Hi, thanks. Yes I've tried the steps and followed the advice online and in the app. Sky glass is working fine downstairs now after resetting but the stream box upstairs will not move past the step where I have to hold the 4 and 6 buttons on the remote for 2 seconds, it will not respond to this? I have new batteries in the remote and it is lighting up. I have pointed it right next to the box whilst holding the 4 and 6. I do not know what to do from here. Any advice and help is much appreciated. Thanks.
This message was authored by: Brian225
You're lucky, my puck refuses to work.....
Avatar for GD1
Level 16 icon
@ClareP123  I have merged your post to this existing thread that is discussing the same issue, you keep posting  on an older unrelated thread, please can you post replies to this thread only?
What happens if you pull the power and turn back on
Avatar for GD1
Level 16 icon
Re: Hi my sky puck hasn’t worked for 3 days I’ve tried everything suggested any ideas ?
@Gemma411  Have you tried the full stpe in post 2 of this thread?   If so how far are you getting.
Please note the usual unplugging and plugging back in won't work for this issue.
What kind of scenic pictures ? Are you sure this is not a screensaver built into your tv ?
Try this
Pull your plug out
press and hold the standby button on the bottom  of the puck as you look at it
put the plug back in while still holding the standby button
keep holding the standby button until the light at the front of the tv starts flashing
let standby button go
follow on screen prompts
when you get to the pin screen pull the plug again and turn back on
This message was authored by: BobW2
Have gon through reset  and activation again,  and it has worked - for the time being. Has anyone else had this issue -  sucessful reboot and  rstoration of service  to have it go down  again? I don't understand what is causing the problem.
Locked
Answered - Go to Answer
