Discussion topic: Sky Glass Power up Issues 19-9-24
Message posted on 21 Sep 2024 06:38 PM
Re: Still no sky glass tv won’t switch tried suggested advice now 3days
Yes and yes. 😞
Message posted on 21 Sep 2024 06:40 PM
Re: Sky glass down and no one answering our calls
Yup, SKY glass is **bleep**
Message posted on 21 Sep 2024 06:42 PM
Re: Sky Glass Power up Issues 19-9-24
@Paulbuckland557 wrote:Thanks for the recommendation lettuce.
However, I tried allllll of that before.
Tried again just now.
Used my mobile, on 5g (not connected to my home wifi), and cleared all web history, cookies etc.
Still it will not activate.
Mobile on Web page says successfully activated. Glass does nothing.....:(
Are you logged in with the correct sky id for your television ? Some users have two sky id s - one for mobile and one for tv
Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
My sky streaming has been down for 4 days, I've spent over 4 hrs on the phone trying to get this sorted and keep getting disconnected whilst on hold. They have tried to take the payment still even though the service is not working, now they are threatening me with late fees this is an absolute joke!!
Seriously thinking about going to another provider now as had nothing but problems with it from the start and the prices are now 3 x what I started with. Another hour on hold today and cut off 1hr 1min into the call.
Message posted on 21 Sep 2024 06:43 PM
Mine still off - managed to get through on phone said give it another 24 hours- I asked about compensation for lack of tv - he did not know ! So I presume that means no !
Message posted on 21 Sep 2024 06:46 PM
Re: Still. No sky stream since Thursday evening
@Reilly9 The set won't correct itself and the advise to wait 24 hours seems to be incorrect as there are steps posted in post 2 of this thread that should work for most people, have your tried these steps at all?
We should all just take our TV's in to store, that's where I'm heading on Monday
Message posted on 21 Sep 2024 06:47 PM
Re: Sky glass not worked since Thursday i follow instructions but cant get past "linking unsucc
Mine is the same but i can't even get past software updating screen. Really annoying.
@Reilly9 wrote:Mine still off - managed to get through on phone said give it another 24 hours- I asked about compensation for lack of tv - he did not know ! So I presume that means no !
The fix was issued this morning..... it's on post 2 of this thread
Have you tried the steps in this thread? Post 2?
Message posted on 21 Sep 2024 06:48 PM
I still have no sky glass this is not acceptable. You can't even speak to anyone. I have done all the resets as stated and still nothing. I hope I get a rebate
Re: Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
That's correct. Billing continues throughout any fault/outage, in fact the bill was generated 14 days before your payment date. If you don't pay it late fees are applied.
@Nella wrote:I still have no sky glass this is not acceptable. You can't even speak to anyone. I have done all the resets as stated and still nothing. I hope I get a rebate
Where is the fix not working for you?
Message posted on 21 Sep 2024 06:52 PM
@Mark081975 universal problems with Sky Glass started on 19th. Did your problems start before that, then? If so, what's happening exactly?
