4306
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by: Kdoodle
Re: Still no sky glass tv won’t switch tried suggested advice now 3days
Yes and yes. 😞
This message was authored by: NICKRANGER1
Re: Sky glass down and no one answering our calls
Yup,  SKY glass is **bleep**
This message was authored by: Jporch316
Re: Sky Glass Power up Issues 19-9-24
@Paulbuckland557 wrote:
Thanks for the recommendation lettuce.
However, I tried allllll of that before.
Tried again just now.
Used my mobile, on 5g (not connected to my home wifi), and cleared all web history, cookies etc.
Still it will not activate.
Mobile on Web page says successfully activated. Glass does nothing.....:(
Are you logged in with the correct sky id for your television ? Some users have two sky id s - one for mobile and one for tv
This message was authored by: Mark081975
Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
My sky streaming has been down for 4 days,  I've spent over 4 hrs on the phone trying to get this sorted and keep getting disconnected whilst on hold. They have tried to take the payment still even though the service is not working, now they are threatening me with late fees this is an absolute joke!!
Seriously thinking about going to another provider now as had nothing but problems with it from the start and the prices are now 3 x what I started with. Another hour on hold today and cut off 1hr 1min into the call.
This message was authored by: Reilly9
Mine still off - managed to get through on phone said give it another 24 hours- I asked about compensation for lack of tv - he did not know ! So I presume that means no !
This message was authored by: Cdrw111
Re: Still. No sky stream since Thursday evening
Avatar for GD1
Level 16 icon
@Reilly9  The set won't correct itself and the advise to wait 24 hours seems to be incorrect as there are steps posted in post 2 of this thread that should work for most people, have your tried these steps at all?
This message was authored by: LIFETISABALL13
We should all just take our TV's in to store, that's where I'm heading on Monday
This message was authored by: Michelle158
Re: Sky glass not worked since Thursday i follow instructions but cant get past "linking unsucc
Mine is the same but i can't even get past software updating screen. Really annoying.
The fix was issued this morning..... it's on post 2 of this thread
Avatar for GD1
Level 16 icon
Have you tried the steps in this thread?  Post 2?
This message was authored by: Nella
I still have no sky glass this is not acceptable.  You can't even speak to anyone.  I have done all the resets as stated and still nothing.  I hope I get a rebate
Re: Streaming has been down for 4 days spent over 4hrs on the phone keep getting disconnected
@Mark081975
That's correct. Billing continues throughout any fault/outage, in fact the bill was generated 14 days before your payment date. If you don't pay it late fees are applied.
Where is the fix not working for you?
@Mark081975 universal problems with Sky Glass started on 19th. Did your problems start before that, then? If so, what's happening exactly?
Locked
Answered - Go to Answer
