4306
Discussion topic: Sky Glass Power up Issues 19-9-24
Locked
This message was authored by Taka1 This message was authored by: Taka1
Is anyone having problems turning Sky glass on?
I have not been able to turn my sky glass on for 2 days straight. Has anyone had the same issue?
This message was authored by Jporch316 This message was authored by: Jporch316
Re: Sky Glass Power up Issues 19-9-24
@Chloe240 wrote:
Have tried this. Still no luck, still stuck on a blue screen saying 'updating software' but is not doing anything.
Are you able to plug an ethernet cable into your puck temporarily to see if this works
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
@Stacy8 wrote:
It is not working for all users. Some users devices are still down
You need to follow the recovery procedure on post 2 of this thread to get your device back working
This message was authored by Anita35 This message was authored by: Anita35
Still down, tried everything, it gets as far as the Sky word on screen then goes black. On hold now for the past 30 mins listening to music and noone to say where I am in the queue. Really bad customer service.
This message was authored by lettice This message was authored by: lettice
This is the resolution that works and that you have to do.
Follow the procedure exactly that mentions Sky Glass Tv  exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
https://helpforum.sky.com/t5/Sky-Glass-Live/Sky-Glass-Power-up-Issues-19-9-24/m-p/4757859#M147519
This message was authored by Fellwalker46 This message was authored by: Fellwalker46
Re: Sky Stream reboot
Hi. There is an issue with sky stream and sky TV , I'm not entirely sure what happened but its affecting lots of people and no one is getting a proper answer. I got my sky stream working by unplugging the box, waiting 10 minutes and rebooting. I don't know if this has fixed the issue as I've left the box switched on overnight.
Re: Sky glass still not working
@Emmaalfie12 wrote:
My sky glass is still down! Resetting it or turning tv off for a period of time hasn't helped!! Any other ideas? Black screen of death is getting annoying now! Especially with how much I pay a month
This message was authored by Stacy8 This message was authored by: Stacy8
I understand. It just hasn't worked for a number of users. Like myself
This message was authored by Nix37 This message was authored by: Nix37
I have stream and followed the steps BUT the activation page is working probably due to amount of people trying it!
Where is it going wrong ?
This message was authored by Dean1288 This message was authored by: Dean1288
Same here, it will not accept my 4 digit pin
This message was authored by BobW2 This message was authored by: BobW2
Have been following the sky  instructions exactky for  over 24 hours  Puck does not reset and turn on no matter how many time I  disconnect power, reconnect and hold the rest button till the white then coloured lights start  flashing.  Afer 15+ minutes Puck will not  turn on. What is the problem?
This message was authored by Brian300 This message was authored by: Brian300
How long it going to be when it back on
Follow the procedure exactly as described in post 2 of this thread, flagged as the Answer post from Sky.
This message was authored by Havill This message was authored by: Havill
Re: Martin my sky glass TV is not turning on
I'm still not getting any response with my sky glass tried everything been on the phone 50 mins not happy
Locked
