2923
Discussion topic: Sky Glass Power up Issues 19-9-24
This message was authored by CliveB1 This message was authored by: CliveB1
Sky Puck won't trun on
Sky Puck won't trun on, led light flashs and I get sky come up on screen then gose off? Anyone know what to do?
This message was authored by vicki41 This message was authored by: vicki41
Re: Stream puck won't turn on
Same with me, I can't get the puck to turn on. I've turned the power off and on, I've followed the online guidance (pressing 4 & 6), pressing the standby, turning the power off and on, waited for the flashing lights, remove finger and waited. The puck will flash with a white light and the SKY logo comes on the screen then its off again. Been trying for the last 2 hours but no joy.  Does anyone else have any guidance. I've even put new batteries in the remote but nothing seems to work to get it to start up as usually does
This message was authored by Daviedee This message was authored by: Daviedee
Looks like the issue is with restarting or switching on. We were fine but noticed that the channels were distorted slightly whilst watching itv. Waited till the ad break and soft restarted the device, wish I hadn't now. Have to make conversation with the OH now 😉
This message was authored by M231 This message was authored by: M231
Tv & puck not working!!
Hi my sky glass tv won't come on & neither will the puck! Whole system not working,
This message was authored by Dave3010 This message was authored by: Dave3010
Sky glass not turning on
TV not turning on after multiple efforts to reset.  Seems to be a known issue?
This message was authored by Marie54 This message was authored by: Marie54
Hi My puck won't turn on either, nothing posted to keep me updated just states outage in area?
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Re: Sky Glass Power up Issues 19-9-24
@Katiec wrote:
Ugh! Ours is off too! Stupid flashing red light, won't reset! I know it's a first world problem and all that but when you pay so much for it it's really annoying! Will they let us know when it's back??
I HATE sky glass!
Yes via the service checker you can access via My Sky which provides outage updates.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
This message was authored by Emij_0803 This message was authored by: Emij_0803
Re: Sky Puck won't trun on
Sky are aware of the issue and are working to fix it
This message was authored by DK197424 This message was authored by: DK197424
Sky Glass - Unable to Connect to Router - despite factory reset of TV
Hi, My SkyGlass TV got delievered today and we are unable to connect to Internet. All other devices in our house are working fine. We did all sort of troubleshooting, shutting the TV on and off, shutting the router on and off. Factory reset of the TV etc.
WPS option does not work, WIFI password does not work, Entering manually the WIFI settings does not work, Ethernet Hard wiring does not work
Did we make a bad investment ? how do we get this funtional (if at all ?)
Regards
Daksh
This message was authored by Bhups This message was authored by: Bhups
I have the same issue!
Exactly there is an outage affecting your service. Once it's fixed it will report as their being no outage and the service is working.
NOT a Sky Employee
This message was authored by rrjbrighton This message was authored by: rrjbrighton
Is this a national or a local issue?  I'm in East Sussex.  Where are you guys?
This message was authored by ashmillin This message was authored by: ashmillin
Re: Martin my sky glass TV is not turning on
I tried this, it begins the software update and completes to 100% but then I get the black screen with the sky logo for a minute and then it's back to a black screen with the red light on a slow flash on and off.
Tried resetting the remote control as well but not sure if that's worked. It wont respond to the remote on/button or the one in the tv either.
But it would be helpful to know if problem being worked on and when it will be expected to be resolved
This message was authored by Robert117 This message was authored by: Robert117
Re: Sky glass to not powering on. Tried reset not working. Sky on phone 50min hold time. Anyone kn
What did Sky say????
