Discussion topic: FTTP: Voice light goes to orange and the internet stops working.
Message posted on ‎06 Mar 2024 09:19 AM
Re: On the new sky hub there is a solid orange light on voice part of the router display
@Jambo75 If you could during your next voip orange light, try just removing the ethernet connection on your wan connection to the ont, then plugging back in to see if operation starts, this is rather than powering down the router to reset, and post back your result if you dont mind.
Message posted on ‎08 Mar 2024 10:23 AM
Service installed 10 days ago. Amber voice light for a week. No help from Sky?
Hi,
We had Ultrafast installed last Tuesday, but since Saturday the voice light on the router has been amber, and no amount of rebooting or changing of cables will make it gree again. There's no inbound calls being recieved and we can't call out (no dial tone). A handful of times over the week, the box seems to have rebooted itself, but again, the issue remains.
I tried raising the problem with the online Service Checker, which texted me to say the issue had be resolved (it wasn't), so I tried again - same story. I then called support, who told me they could "see the issue on the line" and that it would go away within "a couple of hours". Surprise, surprise, it didn't...
What's going on? How do I get someone to sort this problem? We have no phone line for a week and Sky seems utterly unbothered by the problem. Should I just cancel and go back the the old, working broadband service??
Message posted on ‎08 Mar 2024 11:07 AM - last edited: ‎08 Mar 2024 11:09 AM
Re: Service installed 10 days ago. Amber voice light for a week. No help from Sky?
Typically there's no route back from Ultrafast to a Superfast product at an address now that new PSTN services are not available on the wholesale market: in particular a copper circuit cannot be reactivated once full-fibre is in place. Unfortunately you'll need to persist with Sky to get the situation resolved by Openreach.
Message posted on ‎08 Mar 2024 11:33 AM
Ah, that explains why Sky seem to be resting on their laurels in getting the problem resolved then - I have zero recourse beyond moving to cable-based services for everything??
Message posted on ‎08 Mar 2024 11:40 AM - last edited: ‎08 Mar 2024 11:50 AM
PSTN reached stop-sell nationally in September last year, so ISPs cannot order PSTN voice service either as new provisioning or a 'reconnection'. If your Ultrafast order involved the fitting of FTTP, that's now the only circuit which Openreach / BT Wholesale will sell service over or maintain going forwards.
Alternative provision would be from Virgin or an altnet full-fibre ISP laying its own infrastructure: Openreach are obliged to resolve your current issue but their timescale for doing so is entirely unpredictable, and as a subscriber you can only talk to Sky as the ISP, not Openreach directly.
Message posted on ‎08 Mar 2024 06:21 PM - last edited: ‎08 Mar 2024 06:26 PM
I should clarify one point I raised above: it is possible to order a Superfast speed product (40Mbs or 80Mbs) over an FTTP circuit capable of gigabit Ultrafast. What's typically not possible is a return to the physical FTTC connection.
Message posted on ‎11 Mar 2024 09:14 PM
WiFi
WiFi signal drops but broadband connection is fine. Fourth on right light named 'voice' turns amber
Message posted on ‎11 Mar 2024 09:16 PM
Re: WiFi
@Andrew7234 Could you please post your router stats following the link below.
Message posted on ‎11 Mar 2024 09:50 PM
Re: WiFi
Trying to share but won't let me post photos says I don't have rights
Re: WiFi
Re: WiFi
Got it now
Message posted on ‎11 Mar 2024 10:28 PM
Re: WiFi
@Andrew7234 Did you reset the router yourself or did it powercycle?
Message posted on ‎12 Mar 2024 05:26 AM
Re: WiFi
Did a reset myself last week
Message posted on ‎12 Mar 2024 09:23 AM
Re: WiFi
@Andrew7234 The next time it happens do not reset the router right away. Could you then post the router stats again to see if there is a drop in the connection. This will give the community a better idea of what is going on.
Message posted on ‎29 Mar 2024 11:17 AM - last edited: ‎29 Mar 2024 12:02 PM by Kelsingra
Internet Drops out on FTTP Service
I've upgraded to Sky Broadband Ultrafast 1, FTTP install, and since it was installed 6-8 weeks ago, at least twice a week I lose complete internet. first few times, I rebooted the router, solved the issue. I rang the sky support team, they said it was a settling issue, and shoudl reboot the fibre box instead. I did that the next few times. It is still happening.
There is no pattern to it, middle of the day, evening, night. the family using the intenet, no one in the house.
A reset of either the OR ONT or Sky Router fixes the problem. Syslog from the sky router shows this.
10:35:38 syslog: TR69: Connect to Production ACS
10:35:38 syslog: TR69: Connection to ACS Complete
10:35:50 syslog: TR69: Close ACS Connection
10:39:36 syslog: WAN IPV6 UP
10:50:05 syslog: [626443.416000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:50:06 syslog: eth3.1 - WAN link DOWN.
10:50:06 syslog: DHCP lease expired from server. Connection DOWN.
10:50:07 syslog: [626445.445000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:50:11 syslog: Voice IP Connection Down
10:50:14 syslog: Voice Disconnected
10:55:55 syslog: [626792.654000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:55:55 syslog: sky dhcpc client (v0.0.1) started
10:56:01 syslog: sky dhcpc client (v0.0.1) started
10:56:21 syslog: [626818.820000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:21 syslog: sky dhcpc client (v0.0.1) started
10:56:24 syslog: [626821.847000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:56:24 syslog: sky dhcpc client (v0.0.1) started
10:56:26 syslog: [626823.859000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:26 syslog: sky dhcpc client (v0.0.1) started
10:56:29 syslog: [626826.884000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:56:29 syslog: sky dhcpc client (v0.0.1) started
10:56:34 syslog: [626831.916000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:34 syslog: sky dhcpc client (v0.0.1) started
10:57:04 syslog: sky dhcpc client (v0.0.1) started
10:57:11 syslog: eth3.1 - WAN link UP.
10:57:11 syslog: Received valid DHCP lease from server. Connection UP.
10:57:11 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: (removed)
10:57:21 syslog: WAN IPV6 UP
10:57:21 syslog: Voice IP Connection Up: (removed)
10:57:21 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: (removed)
10:57:21 syslog: TR69: Connect to Production ACS
10:57:21 syslog: TR69: Connection to ACS Complete
10:57:31 syslog: TR69: Close ACS Connection
10:57:32 syslog: Voice Configured
10:57:36 syslog: Voice Initialized
10:57:36 syslog: Voice Connecting
10:57:37 syslog: Voice Connected
Issue seen at 10:55 today. Reset the ONT at 10:56. Seems to have happened at 1050.
Any help or guidance on this issue?
Moderator note: Removed personal/identifiable details
