51
This discussion topic has been answered Discussion topic: Sky Fibre & Unifi Dream Machine
This message was authored by: -rpnz-
Re: Sky Fibre & Unifi Dream Machine
Posted by a Sky employee
@anon412332 wrote:
I might be wrong, as I didn't capture a packet before, but Release Candidate (Network 8.6.9) I can't see option 95 in the DHCPv6 request i wiresharked
I could be missing it as i didn't capture a before so not sure what I'm looking for, but what I _think_ was the list  list of DHCP options i couldn't see 95.
Hopefully @-rpnz- 's life gets a bit easier soon.
In the DHCPv6 Solicit the MAP-T Option 95 code gets encapsulated inside the Option Request option 6, like such:
These are all the options the client is requesting from the server; not all of them will get a response.
This message was authored by: anon412332
OK, so it was that obvious... I just plugged into my old console on old firmeware, and it's got those options there, and verified that in the release candidate they're gone. (Helpfully I didn't see that reply until after i'd done that, the image wouldn't load on mobile)
So yeah, it's not MAP-T support, but it's not falsely declared MAP-T support.
I suspect it'll be released in about 2-4 weeks if normal cadence sticks.
Thanks for confiming @anon412332 , that's good news!
Fingers crossed they eventually do start supporting MAP-T, but at least that mitigates the issue in the meantime.
This message was authored by: Amandeep5
I have the same problem today. Tried everything disabled ipv6. But no internet. Udm has wan ip 100.something.
In ipv4 DHCPv4 selected no option selected
Ipv6 Disabled.
Any help would be much appreciated.
Wife wasn't already happy about changing to sky.
You'll need to turn the modem off for an hour or two... that will cause the connection to drop, and then the next time you connect (with IPv6 disabled) then you'll be connected to the traditional pool...
(then whenever 4.1.9 releases, you can upgrade to that, and reactivate IPv6)
If you messages @-rpnz- he can get your account in the excluded pool, BUT it's xmas and he's probably away by now.
so in the meantime, you need to disconnect (ideally if you can just leave it overnight that would be super conversative) and then reconnect without IPv6 enabled on the wan.
Merry *expletive here* Christmas to you and your marriage.
Thank you for taking your time out to reply during this festive period.
I have plugged in the sky router and still got my unifi setup behind it. So marriage is safe for now...lol.
Will try these instructions.
Merry Xmas everyone.
As of last week Unifi 4.1.13 for cloud gateways and dream machines is now official.
So unless that's regressed since 4.1.9, that a normal software release should remove the inaccurate DHCPv6 headers.
Answered - Go to Answer
