Discussion topic: Recently upgraded from SuperFast to UltraFast+ and now seeing pixelation when streaming
This message was authored by: TapeHead
Never had pixelation with SuperFast.
The pixelation takes up roughly half the screen & lasts for microsecs & happens every 2/3mins.
Here's my stats:
Re: Recently upgraded from SuperFast to UltraFast+ and now seeing pixelation when streaming
@TapeHeadthe router stats look stable. What platform is this happening on and does it happen on all devices using the same platform?
Avatar for TapeHead
Level 3 icon
The only TV streaming via the Qrouter is a Samsung.
@TapeHead  Are you saying that you have the router the Sky Q hub for your broadband that looks like the third router in the link below.
Avatar for TapeHead
Level 3 icon
I have the Sky Broadband hub - the middle picture.
@TapeHead
When you say sky q router do you mean the sky q satellite box?
How is the sky q connected ie wifi or ethernet and are you uslng any ethernet switches
@TapeHead  I was wondering with you having ultrafast broadband and using a Sky Q hub. But seems that is cleared up with the question from @cookiemonsteruk
@Highlinder
Just trying to figure what significance 173 collision packets would be if @TapeHead was streaming through sky q on that ethernet connection
@cookiemonsteruk  That does seem a lot for sure if that is all that is connected via ethernet.
Avatar for TapeHead
Level 3 icon
The SkyQ2TB box is connected to the hub by wifi.
I re-booted the former yesterday - no improvement.  I'd previously reset (& then re-booted) the hub as soon as the pixelation started.
I'll put in a call to Sky.
