08 Mar 2024 11:33 AM
Ah, that explains why Sky seem to be resting on their laurels in getting the problem resolved then - I have zero recourse beyond moving to cable-based services for everything??
08 Mar 2024 11:40 AM - last edited: 08 Mar 2024 11:50 AM
PSTN reached stop-sell nationally in September last year, so ISPs cannot order PSTN voice service either as new provisioning or a 'reconnection'. If your Ultrafast order involved the fitting of FTTP, that's now the only circuit which Openreach / BT Wholesale will sell service over or maintain going forwards.
Alternative provision would be from Virgin or an altnet full-fibre ISP laying its own infrastructure: Openreach are obliged to resolve your current issue but their timescale for doing so is entirely unpredictable, and as a subscriber you can only talk to Sky as the ISP, not Openreach directly.
08 Mar 2024 06:21 PM - last edited: 08 Mar 2024 06:26 PM
Posted by a Superuser, not a Sky employee. Find out moreI should clarify one point I raised above: it is possible to order a Superfast speed product (40Mbs or 80Mbs) over an FTTP circuit capable of gigabit Ultrafast. What's typically not possible is a return to the physical FTTC connection.
11 Mar 2024 09:14 PM
WiFi signal drops but broadband connection is fine. Fourth on right light named 'voice' turns amber
11 Mar 2024 09:16 PM
Posted by a Superuser, not a Sky employee. Find out more@Andrew7234 Could you please post your router stats following the link below.
11 Mar 2024 09:50 PM
Trying to share but won't let me post photos says I don't have rights
Got it now
11 Mar 2024 10:28 PM
Posted by a Superuser, not a Sky employee. Find out more@Andrew7234 Did you reset the router yourself or did it powercycle?
12 Mar 2024 05:26 AM
Did a reset myself last week
12 Mar 2024 09:23 AM
Posted by a Superuser, not a Sky employee. Find out more@Andrew7234 The next time it happens do not reset the router right away. Could you then post the router stats again to see if there is a drop in the connection. This will give the community a better idea of what is going on.
29 Mar 2024 11:17 AM - last edited: 29 Mar 2024 12:02 PM by Kelsingra
I've upgraded to Sky Broadband Ultrafast 1, FTTP install, and since it was installed 6-8 weeks ago, at least twice a week I lose complete internet. first few times, I rebooted the router, solved the issue. I rang the sky support team, they said it was a settling issue, and shoudl reboot the fibre box instead. I did that the next few times. It is still happening.
There is no pattern to it, middle of the day, evening, night. the family using the intenet, no one in the house.
A reset of either the OR ONT or Sky Router fixes the problem. Syslog from the sky router shows this.
10:35:38 syslog: TR69: Connect to Production ACS
10:35:38 syslog: TR69: Connection to ACS Complete
10:35:50 syslog: TR69: Close ACS Connection
10:39:36 syslog: WAN IPV6 UP
10:50:05 syslog: [626443.416000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:50:06 syslog: eth3.1 - WAN link DOWN.
10:50:06 syslog: DHCP lease expired from server. Connection DOWN.
10:50:07 syslog: [626445.445000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:50:11 syslog: Voice IP Connection Down
10:50:14 syslog: Voice Disconnected
10:55:55 syslog: [626792.654000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:55:55 syslog: sky dhcpc client (v0.0.1) started
10:56:01 syslog: sky dhcpc client (v0.0.1) started
10:56:21 syslog: [626818.820000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:21 syslog: sky dhcpc client (v0.0.1) started
10:56:24 syslog: [626821.847000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:56:24 syslog: sky dhcpc client (v0.0.1) started
10:56:26 syslog: [626823.859000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:26 syslog: sky dhcpc client (v0.0.1) started
10:56:29 syslog: [626826.884000] eth3 (Ext switch port: 4) (Logical Port: 12) Link DOWN.
10:56:29 syslog: sky dhcpc client (v0.0.1) started
10:56:34 syslog: [626831.916000] eth3 (Ext switch port: 4) (Logical Port: 12) Link UP 1000 mbps full duplex
10:56:34 syslog: sky dhcpc client (v0.0.1) started
10:57:04 syslog: sky dhcpc client (v0.0.1) started
10:57:11 syslog: eth3.1 - WAN link UP.
10:57:11 syslog: Received valid DHCP lease from server. Connection UP.
10:57:11 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: (removed)
10:57:21 syslog: WAN IPV6 UP
10:57:21 syslog: Voice IP Connection Up: (removed)
10:57:21 syslog: Connection Up. SNO/MAC/IP/SWVER/IPv6: (removed)
10:57:21 syslog: TR69: Connect to Production ACS
10:57:21 syslog: TR69: Connection to ACS Complete
10:57:31 syslog: TR69: Close ACS Connection
10:57:32 syslog: Voice Configured
10:57:36 syslog: Voice Initialized
10:57:36 syslog: Voice Connecting
10:57:37 syslog: Voice Connected
Issue seen at 10:55 today. Reset the ONT at 10:56. Seems to have happened at 1050.
Any help or guidance on this issue?
Moderator note: Removed personal/identifiable details
29 Mar 2024 12:04 PM
Posted by a Superuser, not a Sky employee. Find out more@MD3 what happens to the leds on the ONT and hub when the connection is lost?
29 Mar 2024 02:04 PM
On the sky hub voice led changes amber. No other lights change. And the ont has no red lights on it. It's like it just stops communicating somewhere. The logs don't show anything else other than what I've put in the original post
02 Apr 2024 12:16 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat do you have connected to ethernet port 4 of your Sky hub? The ONT?
