02 Mar 2023 10:02 AM
Posted by a Superuser, not a Sky employee. Find out moreI think the obvious thing to try is to go into your Sky routers settings, switch WiFi off completely and connect Sky Q to your Deco
02 Mar 2023 11:19 AM
The network design looks good, so the issue is a fault with the Sky Hub or Sky Q box. Certainly, something that should be escalated to Sky.
02 Mar 2023 11:58 AM
@jamesn123 I have tried that several times without success.
Even if I completely reset the network adapters on the Sky Q by going into the engineering menu, it doesn't seem to want to hold on to the network via the AP. Best was about 12 hours before it dropped off.
