17 Feb 2023 11:34 AM
I am experiencing issues with broadband connected to encrypted websites (https)
I have a TP Deco Mesh Wifi system plugged into the Hub and Hub Wifi disabled.
On many encrypted sites that I try and connect to the browser just hangs. Can take a minute or more to load, or time out completely.. When I connect to the same site on mobile data on the same device, it works fine.
Guess it's a security thing on broadband but I can't see anything that would cause a problem.
21 Feb 2023 10:22 AM
Posted by a Superuser, not a Sky employee. Find out moreCould be down to the fact you are using two routers on the network. Did you put the Deco in AP mode?
21 Feb 2023 02:19 PM
Thanks @jamesn123 changed to AP mode on the Deco and that seems to have improved it, though still getting some sticky pages.
Created a new problem getting my Sky Q box on the network but have worked through some other discussions and seem to have managed that for now. Though I did have to turn the hub wifi back on and use that. I'm hoping that the Deco is smart enough to work around other networks.
21 Feb 2023 03:15 PM
Routing through 2 routers (double NAT) should not cause an issue with encrypted sites, only incorrect DNS responses would cause that issue and would usually be down to the broadband shield and age restrictions on the shield. Or a similar DNS restricting facility on the Deco system when in double NAT routed mode.
21 Feb 2023 03:19 PM
But routing through two routers could cause temporary network stalls which makes it seem like sites wont load.
21 Feb 2023 03:22 PM
Absolute nonsense, I run double NAT here and so do many others it is even used on the internet behind hidden networks, eg: mobile networks without any issues whatsoever in that respect without stalls.
21 Feb 2023 03:25 PM
No need to be so hostile. I did not say it would happen I said its possible. If the two routers are conflicting with each other in terms of IP address space or particular devices, namely a Sky Q box which can take out an entire network if its not happy with its ethernet connection, then one could easily experience network 'stalls' e.g. packet collisions.
21 Feb 2023 03:30 PM
If the IP address space conflicts then it won't work at all and it certainly wouldn't only impact encrypted sites only unless there is some form of traffic interception or incorrect DNS responses which is basically the same as an interception.
And sorry about being a little sharp, that wasn't intended.
21 Feb 2023 03:52 PM
One thing I agree with @jamesn123 is if you have the issue you are experiencing with double NAT then you have made a fundamental misconfiguration of the Deco system behind the Sky router.
1. You cannot wire the Sky Q system to the Deco system unless you do the complete Sky Q system and disable the Sky router wireless system.
2. The IP private address space on the Sky system is 192.168.0.1/24 and the Deco must be on a separate subnet outside this range if you wish to double NAT and route through both routers.
22 Feb 2023 09:58 AM
Hi @mae-3
I have the Deco in AP mode now and after fully resetting the wifi adapter on the sky Q have managed to get it to join the network via the Deco.
Still some problematic pages when accessing via wifi though which I can't see are linked to parental controls as I have no special rules set. The national lottery seems to cause issues for some reason!
22 Feb 2023 10:07 AM
On the command prompt can you do a 'nslookup national-lottery.co.uk' without the single quotes and post the results?
22 Feb 2023 11:00 AM
22 Feb 2023 11:07 AM - last edited: 22 Feb 2023 11:49 AM
Can you do a lookup of www.national-lottery.co.uk with the command 'nslookup www.national-lottery.co.uk' and post the results, please?
22 Feb 2023 11:12 AM
22 Feb 2023 11:19 AM
The responses from the DNS servers are correct for Sky for IPv4.
Can you try disabling LAN side IPv6 in the router interface, it is under the LAN Advanced setup. And see whether that fixes the issue.
