15
This discussion topic has been answered Discussion topic: 3rd Party Router Configuration
This message was authored by: frowningllamas
Hi All,
Having some troubles setting up my third party router.
Extracted my VDSL login details (the anything@skydsl|anything ones), put it in but does not accept. Used the Sky_MER (DHCP Option 61) profile preconfigured on my router, also tried to set up via PPPoA using the same settings,  VLAN ID etc.
Set it up, switched the cable from my Sky router over, but it won't talk (or maybe Sky won't talk back). Tried to recconnect to the router by using the Sky App to test the line, test showed all okay and that it could connect to the Sky Hub (cable wasn't plugged into hub at the time but was connected to new router).
Can someone help? or maybe someone from Sky can get in touch to help resolve on their end.
3rd Party Router is a TP-LINK Archer VR2100 - https://www.tp-link.com/uk/service-provider/dsl-router/archer-vr2100/  Seems others have had luck with this model.
Re: 3rd Party Router Configuration
@frowningllamas
Which broadband product from Sky are you using?
As noted in this thread, that model of router cannot work for Ultrafast 1 on G.fast as it doesn't contain a G.fast modem.
@frowningllamas
@frowningllamas
What connection type do you have
adsl, copper all the way,vdsl part fibre or fttp full fibre?
Are you in the uk?
Avatar for frowningllamas
Balls, same issue. All that researching and the post made yesterday was the answer.
Thank you for getting back to me, apologies for making you answer the same question twice.
@cookiemonsteruk
Thank you for getting back to me @TimmyBGood solved this for me. Shame, but I shall have to invest in a modem.
@cookiemonsteruk@TimmyBGoodSorry guys, just a quick follow up, just want to double check as I'm not sure if it'll cause any issues. Will the Huawei MT992 be suitable for use with the Sky G.fast service?
@frowningllamas
Yep , thats the original openreach g.fast modem
@frowningllamas
Regarding the tp link it may be possible to authenticate using dhcpv6 prefix delegation as below
1. Connect the network cable from the g.fast  modem to port 4 (labelled LAN/WAN)
2. Login to the router and click advanced at the top.
3. Click Operating Mode and change to "Wireless Router Mode" press "Save"
4. Once ready, while on the "Advanced" setting again, go to "Network" -> "Internet"
5. You will see an empty table, click "Add" in the top right above said table
6. Change Internet Connection Type to "Dynamic IP"
7. Ensure IPv4 remains ticked.
8. Tick IPv6 (wont be selected at the moment)
9. Do not clone mac
10. Press Save
11. Wait, it can take a minute or two but should eventually show connected.
 As the sky mer client identifier only works with the tp own modem
@cookiemonsterukI'll give that a go if the modem doesn't get me sorted 🙂
Seen you on other posts, a wealth of knowledge.
@frowningllamas
The huawei should work its got vlan configured even if the modem itself is n longer receiving firmware upgrades
The issue would be on the tp link side in so far that 80% of exchanges offer dhcpv6 prefix delegation
@cookiemonsterukEnded up going for the ZT Link modem of the same model no., having read some posts on it, its near enough the same as the Huawei model (just was cheapest on Ebay).
I get you, I'll use a combination of the both depending how things go, thank you for the help 🙂 I'll let you know how I get on.
This message was authored by: SamD3
Hello I have an amazon eero pro 7 and when I call sky they say they don't know about pppoe or vlan tags I have fttp 1gig speed I would like some help many thanks
That's correct, because those aren't required when using the hardware which Sky provides.
  • Can I have a step by step instructions on getting a static ip then and knowing my router ip
@SamD3
Sky doesn't offer a static public IP address on any current broadband product.
