325
This discussion topic is read only This discussion topic has been answered Discussion topic: Virgin internet connection problem
Locked
This message was authored by: MattyO84
Re: Virgin internet connection problem
Yes I've done all the reboots and resets, no luck, I even did them again whilst on phone to sky technician, I also re-synced the connection between box and router. It connects to the router but doesn't connect to Internet which the technician said is a VM issue with Sky, as all my other devices are connected fine
This message was authored by: Lyds35
No TV here. Connection is still showing as connected to router but no Internet.
Even logged in to my virgin media to look at all connected devices and its not showing.
I had wondered if it was Virgin who had blocked Sky Glass IP addresses, untill I saw this thread.
This message was authored by: ScottH52
Mine came back last night and was fine. Just put it on and when I select a channel or something to play it's fine but if I press back or home then I get the colour bar across the centre of the screen and can hear the programme playing.  Help please !!
This message was authored by: Tim+Adams
Hi @ScottH52
Unfortunately that's a different fault that's occurred today.
https://helpforum.sky.com/t5/Glass-Stream/Glass-Puck-colourful-horizontal-bar/m-p/4267256#M89879
Thanks,
Tim
Sky Glass, Sky Stream & Sky Protect - FTTP 2.3Gbps
OK thanks I'll check it out
Mine came back on this morning, still a tad slow loading Netflix up through Sky but all other Internet features are working perfectly
This message was authored by: CardiffMan1992
@MattyO84
Glad this is working now for you.
This message was authored by: Edmo117
Sky Glass arrived this morning. Would not do software update until I unplugged it and tried again. Worked for a few mins then no internet connection. Rang Sky. Only took 23 mins to  answer then the guy was a complete waste of space blamed everything on Virgin even though the same port on the router worked perfectly with my laptop. Wound me up si much I got through to the cancellation dept and cancelled the lot. They collect it in 4 days and good riddance. NIT the way to treat paying customers.
@Edmo117
Sorry you had such a poor experience your right though bad customer service can drive customers away.
This message was authored by: Lee10101
Sky Glass and Virgin Media
Hi,
Last week Sky Glass had issues streaming on Virgin.  It was supposedly fixed but It seems to be having issues again.  My WiFi is working fine on all other devices but my Sky Glass won't connect to the Internet.
Can someone please provide an update on this issue
This message was authored by: Jayboy1990
Re: Sky Glass and Virgin Media
My virgin has gone down completely, no connection to router so all my devices are not connected seems to be widespread based on Twitter posts I'm seeing.
This message was authored by: Thewillows
I'm having the same issue again this morning.  Anyone else??
Yes same problem here
This message was authored by: Templar18
Yes just gone off here.. Virgin media seems to be down also here
This message was authored by: Hezzabear
Virgin media is down here too - Essex
Locked
Answered - Go to Answer
