Discussion topic: Using piggy bank data while in Spain.
Message posted on 23 Nov 2021 10:41 AM
Hi,
I am a bit confused with the piggybank rollover use in Spain. My plan has a 10 gig basic useage and I have rolled over 40 gig from my piggy bank. Does this mean that I can use the whole of the 40 gig for streaming etc while I am in Spain?
Regards,
Roland
Message posted on 23 Nov 2021 10:51 AM
Re: Using piggy bank data while in Spain.
Hi @Sticky+Poly that will be fine. This is from sky.
"Data
It works like it does at home, so any data you use will come out of your UK data plan like normal and it won't cost you anything extra.
If you run out of data while you're away, you can still:
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
