726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: IAN-glass
Re: Only getting A-Z sky cinema on sky glass
Just had the same, but asking glass to "show playlist" has solved the issue.
This message was authored by: Variaxfan
Re: Sky glass menu not working
Clearly a national issue and nothing we can do at a local level.  Glad to see the confirmation of that here and appreciate the responses people have given.   We moved to sky glass last year as it was hyped as the new tech.  Wish I'd stayed with sky plus.  It worked much better.
This message was authored by: Miffy1284
Re: Sky Glass stuck on A-Z cinema Screen cannot get to home page 😡
I have the same issue and voice isn't working either neither through telly or remote and remote is connect by pressing 1&3 together.
This message was authored by: xXPurplemistyXx
Re: The Home Screen on Sky Glass isn’t working
You can also use the three dot options button to search for shows... my voice commands weren't working either even though they were already on... until I used the remote and side of TV, I just need to use the htmi cable luckily saying hdmi 1 worked as I couldn't remember which slot I plugged the console in haha
This message was authored by: andywatson1407
Sky menu back online for me - checked at 0815.  Guess the 'config wizard' in their office booted his laptop and reset thing lol
This message was authored by: Dansdictatorship
Sky glass 65" here in northern Ireland and since It switched itself on this morning its stuck on cinema screen , no main screen/home screen.
voice control works but I want to be able to see the available channels ,apps and shows .
Sky fix this issue ASAP!
Once fixed heres a solution,  stop justifying programers jobs by constantly updating software , when something works just leave it be for a good while.
Vote Dan's dictatorship when you see it on the ballot.
Fault now fixed on my system. Life can return to normal etc etc
This message was authored by: IanHarry
Working now.
This message was authored by: Leonie1616
Sky glass tv not working !!!
Has anyone got through to sky regarding sky glass not working ? Still on hold ! ... wondering what they saying the issue is ??
This message was authored by: wozwez
All working again
This message was authored by: Kezzalar
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
Back on now?
This message was authored by: Ljelk
Me too what's going on 🤬🤬🤬
This message was authored by: Jjesso
Fixed thanks sky for speedy response
This message was authored by: Jami3UK
Good morning,
The issue seems to have been fixed for me.  I turned the stream pick off and on again and the homepage appeared.
Jamie
This message was authored by: Alex+Ricote
The home screen is back but the screensaver kicked in after a few minutes of watching TV?
Locked
Answered - Go to Answer
