726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
Re: Dee danny
It's not the result of an update. Sky are aware of the fault and are investigating. Voice control still works in the meantime.
This message was authored by: Wendylou32
Re: Sky glass menu not working phew thought the tv was broken
Phew thought the tv was broken
This message was authored by: Jade1325
Re: Sky glass screen stuck on sky cinema, won’t load from remote
My tv just went off and turn it back on everything back to normal they must of reset it
This message was authored by: skillwill
Working again now
Re: Sky Glass stuck on A-Z cinema Screen cannot get to home page 😡
@Stevierob use voiceccontrol while Sky fix the issue.
This message was authored by: DizzydonDizzydons
Re: My sky glass says, sorry, there are currently no programmes of this type available.
Mine is the same
This message was authored by: Paddywackwack
Fixed! 👍
This message was authored by: Stephanie+Sutherl
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
It's back on
This message was authored by: d3v3
Re: The Home Screen on Sky Glass isn’t working
My homepage has now appeared and working correctly by the looks of it. 👍
This message was authored by: Liam-12345
Mine has started working again
This message was authored by: Ren12345
Back up and running as normal for me now
Re: Only getting A-Z sky cinema on sky glass
There's a fault at Sky's end. They're aware and are investigating. Voice control still works.
This message was authored by: Skyglass049
It's fixed now for me!
This message was authored by: BoatNick
Re: Sky glass
We have the same issue too. So seems systemic
This message was authored by: holyground
yes yes yes alll working now lol
Locked
Answered - Go to Answer
