726
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Glass/Stream Homepage Problems
Locked
This message was authored by: Floydianslip
Re: The Home Screen on Sky Glass isn’t working
@d3v3
mine too!
This message was authored by: Houghy1975
Re: Sky glass menu not working
Patients we pay for a service which is not being delivered how about when it comes to paying then its different
This message was authored by: Nk+mullem
Issue sky glass
Can't get on Home Screen have to use voice. It is stuck on cinema. When will the issue be sorted
This message was authored by: James+herrador
Re: I turn on my tv sky glass and it just keep saying sorry there currently no programmes of this ty
I had exactly the same problem
Keep the TV on be patient and it automatically comes back on
This is the trouble with streaming
This message was authored by: Jami3UK
Re: Sky glass tv not working !!!
Good morning @Leonie1616 ,
I would save yourself time and go about your day, it's a system wide outage and sky are on the case.
Saying that, I turned the sky stream off and back on and the homepage is now working.
Cheers,
Jamie
This message was authored by: JoDiscovery
Sky glass not loading error message and no support available ?
Glass turns on but error message telling me programmes not available ... same on all TVs, nobody about to take call for over an hour .... can't get menus and remote useless
This message was authored by: DizzydonDizzydons
This does work. I have just done it on mine and rang my mum and told her to do the same all good now.
This message was authored by: xXPurplemistyXx
My home menu is back too 🙂 just checked! hopefully everyone else is the same
This message was authored by: andywatson1407
Re: Only getting A-Z sky cinema on sky glass
Menu back on @@0815.
Re: Issue sky glass
I believe a fix has been applied and so should be working soon if not already
This message was authored by: Stevierob
Re: Sky Glass stuck on A-Z cinema Screen cannot get to home page 😡
Just turned off and on again and now back to normal 😉
This message was authored by: Niv
Mines the same and will not reset
very frustrating and must be a sky issue not the TV
This message was authored by: Dansdictatorship
It would appear Dan's dictatorship has caused sky to remedy this issue within a few minutes of Dan's dictatorship pointing out the fault .... the absolute fastest results in politics!!!!
Vote Dan's dictatorship when you see it on the ballot.
This message was authored by: Mrs-allen90
all back on now! hopefully all fixed
Re: Issue sky glass
Good morning,
No one can give you a time frame. It is being looked at by sky though. They know there's an issue.
My service is now working though, the homescreen has loaded.
Cheers,
Jamie
Locked
Answered - Go to Answer
