28
This discussion topic has been answered Discussion topic: Sky Atlantic: "All her fault" problem
This message was authored by: Jims1
Re: Sky Atlantic: "All her fault" problem
We have the same issue you get 4 mins into episode 1, then freezes can not fast forward or rewind goes to a black screen.
we have tested all other episode they seem to be fine and will play
This message was authored by: HORNBYPNE
It freezes at 22 minutes in episode 1 and then exits the download
This message was authored by: KevNewMedia
Posted by a Sky employee
Thank you for the additional information - I've passed this to our support teams 🙂
Kev
Community Manager
This message was authored by: Shannon301
All her fault - Ep 5 won’t load
Episode 5 of All her fault will not play at all, it comes up with a blue screen saying sorry this item is currently unavailable. It has been saying this for the whole day, I am able to watch all other episodes.
This message was authored by: ACS20
All Her Fault Episode 5
Hey,
All Her Fault episode 5 keeps saying, currently unavailable... but episode 6 plays fine. Is episode 5 going to be available soon? I have tried restarting my Glass TV but still doesn't work.
Re: All her fault - Ep 5 won’t load
@Shannon301
I have moved your post to the topic at hand, there is a fault with this that Sky are aware of as you can see by the post from a community manager from Sky.
This message was authored by: Sophie11s
Re: All Her Fault Episode 5
I have this exact issue too. It's stopped half way through and won't let me now play it at all. I  can continue on and select episode 6 with no problems which plays fine but not episode 5. I am watching on sky glass too if that helps engineers.
Re: All her fault - episode 5 not working
Hi @Shannon301 .  I binge watched the entire series this week and had no problem with any of the episodes so it would indicate that there is nothing wrong with the actual broadcast.
I would suggest rebooting your puck by going to Settings > System Management > Resets & Updates > Restart device.  It takes a couple of minutes to completely reboot and you will have a blank screen for a couple of minutes before the Sky logo appears.
Hopefully that wil clear any software glitches 🤞
Thank you for your suggestion but this hasn't helped 😞
This message was authored by: Sparkymatt100
Im using Sky Q and haven't had a problem downloading the UHD version until episode 6. Just watched ep 3,4 and 5 with no issues, Ep 6 downloaded but when I go to play it, I just get a black screen and time plays for a couple secs then bounces back to beginning. Same with ep 7. Have deleted both and deleted forever from deleted folder. Downloaded those episodes again. Same thing, they wont play. Deleted forever ep 5 and downlaoded this again to test. This plays fine, sor for me, its a problem with ep 6 onwards.
I tried another program from On Demand, Fire country S3, ep15 and 16 and the UHD versions start to  play fine so far, so not a problem my end.
LG OLED65C3" 4K HDR TV
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 300
This message was authored by: Tdigger
All her fault
I've been watching All her fault and it's now showing as not available any ideas why
This message was authored by: KLM3
Is there an update on this issue at all? I had been watching series in UHD with no issues until I got to Episode 6 alike another user when it just has the initial couple of credits and then goes black and then back to the beginning. I've tried deleting etc and redownloading which hasn't made a difference and I've also since tried downloading in HD which it will do but wont give me the option to play it...
Avatar for Confused30
This message was authored by: Confused30
No absolutely nothing! I thought it had been reported to sky technicians, obviously not 😱 I still haven't been able to watch episode one .
Ah that's a shame, hopefully something that can be resolved soon. Thank you for responding
Answered - Go to Answer
