13
This discussion topic has been answered Discussion topic: TV Guide Frozen
This message was authored by: fredbloggs10
TV Guide Frozen
TV Guide is Frozen on screen,I can only see the mini screen.
This message was authored by: Annie+UK Answer
Re: TV Guide Frozen
  • Turn the Sky box off
  • Pull the plug out of the wall socket
  • Wait 10 minutes
  • Plug the wall socket back it
  • Listen for the Harddrive to stat spinning
  • Wait for the Sky box to fully start up
  • Take Sky box out of standby (if orange LED)
  • See if that fixes things
Re: TV Guide Frozen
Restart the box by switching off at the plug for 4 minutes.
Avatar for fredbloggs10
Level 2 icon
Re: TV Guide Frozen
Already tried that,no difference
Level 2 icon
Re: TV Guide Frozen
Unplugged and restarted my internet box too,no difference.
Level 2 icon
Re: TV Guide Frozen
Did a Sky Rebuild too,no difference.
Re: TV Guide Frozen
You might have to do a full system reset, see my FAQ
Level 2 icon
Re: TV Guide Frozen
Still happening,I get to see the full live TV picture for about 5 seconds and the the TV Guide fills the screen again.
Re: TV Guide Frozen
Done the full System Reset?
Level 2 icon
Re: TV Guide Frozen
Yes I have
Level 2 icon
Re: TV Guide Frozen
It happens on recordings too.
Re: TV Guide Frozen
  • Wait 10 minutes
Level 2 icon
Re: TV Guide Frozen
I`ve done that twice,no difference. Which number do I call for a Sky engineer to come?
Level 2 icon
Re: TV Guide Frozen
@Annie+UK No difference. When I press the Sky button I see the fullscreen picture for about 5 seconds and then it reverts back to only seeing the TV Guide and Mini-Screen
Re: TV Guide Frozen
You can find the number to call via the 'need more help' dropdown at the bottom of this page:  https://www.sky.com/help
Sounds like the box will need to be replaced.
