Discussion topic: Sky connections
This message was authored by: Fearghal
Sky connections
Hi can i please get help trying to get my shy working it says my sky isnt getting satellite
Avatar for Fearghal
Level 0 icon
Re: Sky connections
Can I get help?
Re: Sky connections
More info would help
What are your Signal Strengths/Qualities? Take a look at the link below:
Question Q11 in my Sky Plus F⋅A⋅Q
Avatar for Fearghal
Level 0 icon
Re: Sky connections
Hi yes my signal boxs are all blue
Re: Sky connections
Check the cables, but is sounds like the dish signal is broken and you'll have to call someone out to fix it
You can contact Sky using the number here (See the "Need more help?" dropdown near the bottom of the page)
Note: Make sure you have the correct country flag selected in the bottom-right of the page
