6
This discussion topic has been answered Discussion topic: System fault
This message was authored by: Rae40
System fault
My planner is not working I have tried the turn on and off multiple times then reset the viewing card nothing works !!
Avatar for Rae40
This message was authored by: Rae40 Answer
Re: System fault
I tried but it failed so sky have agreed to change me to Sky Q for no extra charge but thank you
Re: System fault
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Avatar for Rae40
Re: System fault
Sadly Sky have said the HD box is too old 😳 thank you for your reply though
Re: System fault
@Rae40
Sky no longer support Sky+ set ups but have you tried the advice provided by @Annie+UK ?
Avatar for Rae40
Re: System fault
Re: System fault
@Rae40
I will cc in one of the other Superusers who has compiled a very helpful guide for those thinking of transitioning from Plus to Q which may provide some insight into something you hadn't considered...
cc @nigea99
Re: System fault
hi @Rae40
As @Daniel0210 metioned, you may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
If you have any other questions do not hesitate to ask
