5
This discussion topic has been answered Discussion topic: Replacement Sky Box
This message was authored by: Ogier1
Replacement Sky Box
I have a Sky +HD box. The hard drive is playing up and I keep getting hard drive error messages. I've reset the hard drive a couple of times and it then works for a couple of days before the problem returns. How do I get a replacement box?
This message was authored by: Annie+UK Answer
Re: Replacement Sky Box
There are no new boxes so the secondhand market is the place to go, ebay etc...
Look for the DRX890 or the DRX895 (bigger HDD)
Annie..........    Note: These Sky help forums are primarily for customer-to-customer help
Avatar for Ogier1
How about if I upgrade to Sky Q and would a replacement box be free?
@Ogier1
Sky Q boxes, should you go down that route, are loaned to you but you may pay an admin/activation fee for a mini box. Do your research before deciding.
▪️I AM NOT A SKY EMPLOYEE ▪️
The typical starting point for Sky is to set a high up-front fee and then reduce this if the customer subscribes to add-ons which increase the monthly cost.
The 'VIP Upgrade' to Q is typically 'free' only if Multiscreen is added: that's close to £300 by itself over an 18 month minimum term.
@Ogier1 chances are Sky will want to encourage you to move away from Sky+, and will incentivise you accordingly.
