45
This discussion topic has been answered Discussion topic: Red button and text button on remote does not load
This message was authored by: galaxy1700
Text and red button on sky+ remote will not connect with the service.Message says check your broadband,that is okay,have tried a re boot but still the same.
Service was fine yesterday but nothing to day.
This message was authored by: Chloe-W22 Answer
Re: Red button and text button on remote does not load
Posted by a Sky employee Posted by a Sky employee
Hi all, thank you for flagging this to us!
We've sent it on to our support teams to investigate 🙂
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
Working fine here on BBC One so it's not an issue at Sky's end.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for galaxy1700
Level 2 icon
Is it possibly a problem with set top box?
Or is it the Internet connection to the TV from the router.
Any suggestions welcome,last resort a factory reset for the +box but looses all item saved.
Level 2 icon
All I get text wait then a message to check Internet connection but that works fine on catch up.
This message was authored by: Duncan39
I have a Sky+HD box and have had the same problem today
Level 2 icon
Thanks for info Duncan 39,will see what happens tomorrow if it changes.
@Duncan39
@galaxy1700
Are your issues with BBC1 or a different channel?
All BBC Channels that have text
Level 2 icon
Same with me,all bbc channels that have text service.
Ok. So Ch 101 (which for me is BBC One Yorks) works fine. But 102 and 503 don't work. Assume you are in a different region to me?
So probably a BBC issue.
BBC1 Channel 101 West Midlands does not work
Level 2 icon
Been told by Sky bot service text service on sky + finished.yesterday due to soft water problems,eventually the sky+ box will stop working all together,suggested switching to sky q.
Can you get a text service on sky q as it comes in handy for news etc?
Level 2 icon
Sorry make that SOFTWARE problems
To be clear, Sky+HD boxes won't stop working (unless they become faulty).
Level 2 icon
Just you can not get red button or text service according to them as that service was switched off yesterday,would have been nice to be told.
