Discussion topic: No signal
This message was authored by: Scholesy1
No signal
Through my Sky + multi room  box I can watch terrestrial channels but when I try to watch Sports, Cinema or even Sky News it says 'no signal'.
Signal is showing 'good'.
Strange how I only get certain channels and not others. Subscription is up to date as all channels work on my main box.
Thanks in advance.
Re: No signal
I assume that's 'no satellite signal', rather than 'no signal'. Can you watch these channels on your main Sky+ box?
Avatar for Scholesy1
Re: No signal
States 'isn't getting a satellite signal'.
Confused because if this was the case how would I receive some channels when that's my only source?
thanks
Re: No signal
Oh it's perfectly possible to receive a good signal on some channels and no signal on others, depending on tuning parameters.
Re: No signal
Does that mean it's just a case of getting my dish checked/realigned?
Re: No signal
I've reread your first post and given that all channels are working OK on your main box, it's unlikely to be a dish alignment problem, and more likely an issue with either the LNB (especially if it's more than 5 years old) or possibly cabling.
If yon book an engineer they'll be able to pinpoint the cause.
Re: No signal
Engineer booked. Thanks
