14 Oct 2023 05:47 PM
I have set up my broadband and sky stream yesterday and the volume was working on the sky remote on the initial set up and now it's not working on my Samsung TV
14 Oct 2023 10:49 PM
Posted by a Superuser, not a Sky employee. Find out moreFirstly I would reboot the system by switching off at the plug socket for a minute before switching it on again. I will take about a minute to reboot.
Then try to pair the remote again as follows:
If that doesn't help run through the following help/troubleshooting guides
If it still won't work properly you can request a replacement remote at the following link:
Streaming TV replacement remote (it will make you sign into your My Sky app)
15 Oct 2023 02:08 PM
Thank you for sharing! I will try this method and let you know if the initial guidance helped.
14 May 2024 07:19 PM
My Volume bottoms aren't working on my sky remote how do I get it working again
14 May 2024 09:51 PM
Posted by a Superuser, not a Sky employee. Find out more@Leisha2001 Have a look at post 2 above and try the options listed there. If they don't help there is also a link to request a replacement from Sky.
