05 Mar 2024 07:09 PM
Sky remote volume not working and people talking is out of sync
05 Mar 2024 07:42 PM
@Sandmart wrote:Sky remote volume not working and people talking is out of sync
On the rare occasion I've seen the sound out of sync turning the puck into standby mode and then back on has fixed it for me. The other option is to unplug it for a minute if that doesn't help.
for the volume you may need to reset and repair your remote
21 Nov 2024 06:49 PM
Still no luck
31 Dec 2024 10:43 AM
I have tried everything that has been suggested the volume is still not working but all the other buttons are. Need help
31 Dec 2024 10:47 AM
I tried pressing button seven and nine and then one and three the volume button is still not working. I'll change the batteries restarted the skybox the other buttons on the remote are working but the volume isn't!!!! Yet another problem with sky seems to be a weekly thing
31 Dec 2024 01:27 PM
Got same problem with volume button not working on new sky Q box tried what others have done still nothing how have others fixed it
12 Jan 2025 07:21 PM
Same , also have another remote same thing also voice activation does not work
13 Jan 2025 01:06 PM
No working sky q microphone and volume sound
16 Jan 2025 08:57 PM
Is no one from Sky able to sort this for goodness sake? Ridiculous lack of customer service.
17 Jan 2025 07:54 AM
Posted by a Superuser, not a Sky employee. Find out more@HarryMcM sort out what? The remotes need programming to control a TV as explained in the post marked as the answer Sky cant do that remotely.
20 Jan 2025 09:55 PM
Hi
I don't know if you or anyone else figured this issue but part of the answer is missing...a crucial part actually!
It's no good just pressing 17 and 9 and 1 and 3 etc.
You need a code too.
The solution however is as follows:
On your tv from your Sky Home page, Go down to Settings then set up then set up remote to control TV then it'll ask you to find your tv from the list. Then follow the info
07 Feb 2025 06:56 PM
Handset stopped controlling volume and mute on Streaming. Received new puck. No different. Have spent 3.5 hours on phone trying to sort this out......so they are sending me another puck?! No doubt that will be the same. Original puck was unable to lip sync properly on some channels and kept pixelating as well. AND whilst watching sky sports on two boxes in the same house at the same time on live tv one was a good 20 seconds behind?'?!?!. And streaming is not supported by engineers....I'm not one but expected to get it to work. Crap product.
07 Feb 2025 07:54 PM
Cancelling is likely an option, if you're unhappy with the product?
