Discussion topic: We have no speaking sound only background noise on our sky stream
This message was authored by Timcole3 This message was authored by: Timcole3
We have no speech sound on our sky stream only background noisep
This message was authored by danj3000 This message was authored by: danj3000
Re: We have no speaking sound only background noise on our sky stream
I have this today as well. bbc/itv channels are fine, but sky channels all have this issue.
Timcole3
We don't seem able to contact an actual person at sky to ask about it
This message was authored by Frank+H This message was authored by: Frank+H
Same here but not all channels, only the ones I want to watch. 10 minute wait on customer service 🙄
This message was authored by Joshua9219 This message was authored by: Joshua9219
Backround sound only. Sky Stream
On Sky Sports and Disney+ I have background sound, but no commentary or dialogue. Some apps are ok.
Re: Backround sound only. Sky Stream
@Joshua9219  Try adjusting the sound output on the stream puck by accessing the setting menu - Picture and sound - then select the sound output on hdmi, there are a number of options but try aither pass through, if that doesn't work try pcm stereo
This message was authored by Vivian5 This message was authored by: Vivian5
I've tried both passthrough which didn't work so tried pcm stereo.  I can hear the dialogue if I really turn the volume up but then the background music/sound us blaring.
@Vivian5 check your TV or audio kit as you apppear to be missing the centre channel which carries the dialogue. If its a straightforward stereo set up with only 2 speakers then PCM should be loads better but if you have a centre speaker that isnt working that would explain the issue.
Did you guys solve this? Having the same problem
Thank you but I should have mentioned, it's only on the sky channels -  movies, sky sports, sky witness etc.  plus Netflix, Prime etc.  the terrestrial programmes are all fine.  Also went I go to Netflix, Prime etc outside of Sky stream all fine.
sky has said it's something to do with pointing to 2.4 instead of 5Ghv but it can't be if everything else is ok.
This message was authored by Craig8367 This message was authored by: Craig8367
No dialogue sound on Amazon prime.
No dialogue sound on Amazon prime. Has also occurred on sky sports UHD solved by pressing the 3 dots button on sky remote and selecting audio track- English (AD)
This message was authored by GavinF1 This message was authored by: GavinF1
Any updates guys . Same this end 🙄
This message was authored by MrYeadon This message was authored by: MrYeadon
We've also been experiencing this and for now a workaround is to use the three white buttons on the remote and setting the audio track to "English (AD)"
Fixes dialogue but occasionally you'll get a voice describe what's on screen.
Seems to me an internal sky stream error.
Thanks , will try that . Happening over weekend too . V disappointed as only re signed Bach with sky last month
We have been switching to AD and was good but now we don't even get the option.  This is getting ridiculous now.
