11 Oct 2023 08:59 AM
So I think I've isolated the issue to Sky Stream's "PCM Stereo" setting.
In Audio Settings try using "Passthrough" instead. With this we no longer need to select the AD version channels anymore.
Whilst Dolby options also work, since Voice is typically mixed into centre channel , you'll find voice quieter with these options.
Seems to me however sky are summing to Stereo in PCM they're sourcing the wrong channels.
You will loose menu sounds using "Passthrough" but it's a worthy sacrifice IMO to actually hear what people are saying.
Hope this helps 👍🏻
11 Oct 2023 02:33 PM
Thank You. Appreciate the reply. I have been using AD so far. Can you clarify what you mean by losing "menu sounds".
Thanks again
19 Aug 2024 08:33 PM
Mine was the same. Went to settings. Turned HDMI setting on and off. Hey presto commentary.
