Discussion topic: Sky puck will not stream Netflix, gets between 8 & 24%
This message was authored by: Rossco6
Have Sky puck  and will not stream Netflix, gets between 8 & 24%. 3 pucks in house, only one having problems. The rest of apps and channels work fine, fibre is fine. Have moved pick to see if fault stays with puck and does.
Re: Sky puck will not stream Netflix, gets between 8 & 24%
@Rossco6 On the puck that is having issues try reloading Netflix by going to "Get Help" and select reload Netflix.  This may help clear the issue 🤞
