Discussion topic: Tv and stream
This message was authored by Caz73 This message was authored by: Caz73
Tv and stream
Can I run a sky tv / stream package with the 3  5G broadband package.  ? How do I go about this if it does ?
Re: Tv and stream
@Caz73  5G may not be fast enough as each stream puck needs 25mbps for HD & 35mps for UHD.  Stream needs a constant speed any variation will cause issues.
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek
Re: Tv and stream
I'm sure there have been some people on here who are successfully using Sky Stream using a 5G connection with the 3 network. You need to be absolutely sure that you can get a constant fast and stable signal though, otherwise the Stream pucks start having endless problems.
