Discussion topic: Tv and stream
Message posted on 11 Nov 2024 05:39 PM
Tv and stream
Can I run a sky tv / stream package with the 3 5G broadband package. ? How do I go about this if it does ?
Message posted on 11 Nov 2024 05:44 PM - last edited: 11 Nov 2024 05:49 PM
Re: Tv and stream
@Caz73 5G may not be fast enough as each stream puck needs 25mbps for HD & 35mps for UHD. Stream needs a constant speed any variation will cause issues.
Message posted on 11 Nov 2024 05:47 PM
Re: Tv and stream
@Caz73 wrote:Can I run a sky tv / stream package with the 3 5G broadband package. ? How do I go about this if it does ?
I'm sure there have been some people on here who are successfully using Sky Stream using a 5G connection with the 3 network. You need to be absolutely sure that you can get a constant fast and stable signal though, otherwise the Stream pucks start having endless problems.
