Discussion topic: Sky stream remote not working properly.
This message was authored by: CMcM
My sky stream remote isn't working properly. Some of the buttons are now doing random commands and I can't reset it. Is there a link to get a replacement?
Re: Sky stream remote not working properly.
Hi @CMcM
Try these steps to reset:https://www.sky.com/help/articles/remote-control-help-sky-glass if that's not working speak to Sky customer services or use this online form: https://www.sky.com/help/forms/streaming-tv-remote.
MikeAlanR
Avatar for CMcM
Thanks for the reply Mike! The 2nd link for remote replacement isn't working for me. Coming up as "page not found".
Hi @CMcM
Odd it's working for me. Are you getting as far as signing in? If not you will need to call Sky customer service and they will arrange a replacement.
MikeAlanR
@CMcM you could try clearing your browser cache, or perhaps trying a different web browser to see if that helps.
Avatar for CMcM
Thanks. I rang them and got sorted quickly
