5
Discussion topic: Sky stream and sky glass
This message was authored by Caitlin726 This message was authored by: Caitlin726
I recently purchased the sky stream I believe it was but I've just added the sky glass to my account now which is being delivered tomorrow. Just wondering what happens now? Do I send the sky box back as it's all built into the tv? Will it get taken off my bill now and replaced with the sky glass or am I going to be paying for both even though I no longer need the sky box. Thank you
This message was authored by Mister_Dalek This message was authored by: Mister_Dalek Answer
Re: Sky stream and sky glass
@Caitlin726 wrote:
So on my app it says I have the sky glass, whole home and sky stream. So that is right? I just plug the sky stream into a different tv not the sky glass? Thank you for you reply
Correct. Connect the puck to any other TV in your house and you can view your subscription channels on it via the same Sky interface.
The Sky Glass TV has the user interface built in so you don't need to attach anything to it.
