Discussion topic: Picture and sound dropping out on SSMELSHD Channel 922
Message posted on 24 Aug 2024 07:43 PM
I'm getting fed up with constant picture and sound dropping out
Message posted on 25 Aug 2024 07:48 AM
Re: Picture and sound dropping out on SSMELSHD Channel 922
@Yorkiecherry the live sync channel requires a very stable data feed as it reduuces the amount of data cached in the puck. If you hit issues unfortunately you will need to use the standard feed on ch 401
Message posted on 25 Aug 2024 07:57 AM
@Yorkiecherry wrote:I'm getting fed up with constant picture and sound dropping out
Who is your ISP?
Do you use wifi or ethernet?
What is your router sync speed to the internet?
What is your connection speed to the internet measured using the Netflix Network check?
Message posted on 25 Aug 2024 05:46 PM
I use WIFI and I am with EE. Download speeds 375mps. FFTP connection.
Message posted on 25 Aug 2024 07:45 PM - last edited: 25 Aug 2024 07:46 PM
... and the connection speed measured using the Netflix Network check on the Puck?
Message posted on 26 Aug 2024 03:42 AM
Connection speed via Netflix is340mps
Message posted on 26 Aug 2024 07:56 AM
@Yorkiecherry WiFi speed is perfect, which could point to a couple of other things.
On you phone run a WiFi analyser app, see if any neighbouring signals are on the same channel.
Message posted on 26 Aug 2024 07:59 AM
@Yorkiecherry you should not be having issues with the Live Sync channels with that network set up so I would suggest you report the issue to Sky. This is quite new technology so is still under test as while Sky staff have been testing the technology for sometime not every wrinkle have been ironed out. I assume the regular SSME channel is working well if so use that fir the time being as Sky are continueing to offer that.
Message posted on 26 Aug 2024 11:44 AM
High Speeds don't mean good performance. The most important aspect of your stream performance is low latency. What is the latency on your broadband connection.
Message posted on 26 Aug 2024 04:06 PM
How do I check please?
Message posted on 26 Aug 2024 05:12 PM - last edited: 26 Aug 2024 05:14 PM
download Speedtest.net run a test, it will give speed and latency of your BB connection.
Message posted on 27 Aug 2024 12:40 PM
But not to the Sky Stream servers from a Sky Stream device☹️
Message posted on 27 Aug 2024 12:49 PM
@Exiled-in-HH hence the suggestion for the OP to report the issue to Sky as it could be a routing issue which needs checking out.
Message posted on 28 Aug 2024 08:05 AM
Such information should be available on Pucks without using Netflix🤔
