4
This discussion topic has been answered Discussion topic: Sky Stream pixelating
This message was authored by: AngieMajor
Picture keeps pixelating and freezing.
This message was authored by: Fothergill1 Answer
Re: Sky Stream pixelating
Hi @AngieMajor and welcome to the forum.   This issue has been ongoing for a while now and Sky are aware and are trying to find a solution.
Have a look at THIS comprehensive forum thread on the problem.
This message was authored by: ljmm1967
My sky stream was doing this all day yesterday, so much so that it lost signal on all channels and the screen went completely pixelated with tiny multicoloured pixels. I took the aerial plug out and plugged it straight into the tv and it worked perfectly.
I have the stream hardwired to our router. The router config and speeds are consistently higher than the provider (Vodafone)guarantees. I reset the sky box and all returned to normal.
I don't understand why they have an aerial socket if all channels are delivered via the internet. This is the only time it's done this since we took delivery of it.
This message was authored by: Mick731
I have sky broadband and router. The tv is connected via Ethernet. It is pixelating very all the time. I have changed the picture from auto to vivid but no difference. Please advise
This message was authored by: Mister_Dalek
There's nothing you can do except wait for Sky to fix it.
Answered - Go to Answer
