This discussion topic has been answered Discussion topic: Sky Stream 4K crashing
Message posted on 04 Apr 2026 05:41 PM
Device set to 2160
Sound to Pcm
Device now crashes and freezes or black screen several times a day now, either going from Apple TV or HBO Maxto a HD channel.
Turning off the mains, waiting 30 seconds then turning on sorts it, until I happens again...
On Fttp , getting 90Mb on ethernet speed test via Netflix...I'm suspicious that this new fibre isn't working consistently 100% , fed via underground cable but definitely via overheads to get into the area
Message posted on 04 Apr 2026 07:37 PM
Try exiting the app rather than going straight to the home page. Reason being the app is still open in the background and can cause issues.
Message posted on 04 Apr 2026 05:43 PM - last edited: 04 Apr 2026 05:45 PM
Re: Sky Stream 4K crashing
That would essentially be full speed: pucks only have a 100Base-T ethernet chipset.
Message posted on 04 Apr 2026 05:55 PM
Yes I know, it's the Puck crashing that's getting very annoying seeing how much I pay Sky, so the Puck us on top of the TV bench, but running it on 4k us it overheating?
It's getting close to a call to sky but I don't want another customer refurb device
Message posted on 04 Apr 2026 08:27 PM
Sky puck freezing and then no sound fiber at 910 there's definitely a software issue going on. Anyone else having the same problems
Message posted on 04 Apr 2026 08:55 PM
The answer is sign into Netflix on your tv the link has gone down from sky to Netflix if you do this it will work the sound and picture are a lot better they will fix it.
Message posted on 05 Apr 2026 03:05 PM
Via the back up / return button?
Message posted on 05 Apr 2026 07:54 PM - last edited: 05 Apr 2026 07:56 PM
On most apps press back, back etc. until you quit the app. Netflix needs to "exit" in the menu.
