198
This discussion topic is read only This discussion topic has been answered Discussion topic: Paramount + Freezing With Error 3005 or 9999 (Sky Q/Stream/Glass)
This message was authored by: Janie6
Trouble with the app
keeps buffering then coming up with error 3005
called sky support tried a few things still not working
sky said they can't do much as they don't have access
Moderator note: subject of thread updated to better reflect the conversation
This message was authored by: KevNewMedia Answer
Re: Paramount + Freezing With Error 3005 or 9999 (Sky Q/Stream/Glass)
Posted by a Sky employee
Morning Everyone
I wanted to let you know that our support teams, and Paramount, continue to work on a solution for these problems. As soon as we have more information, we will let everyone known here.
I'll be marking this post as the answer, so that everyone keeps up to date with the most recent information.
Kev
Community Manager
Locked
This message was authored by: Kez191
Re: Paramount +
I have the same issues, only when the ads come on. Really frustrating. I have tried rebooting both the router and puck twice, nothing changed.
Re: Paramount +
If you get the 3005 error on a Sky box.
Do this, it's often helped others.
Start the Paramount+ app on an Android or Apple phone/tablet and play some content, say a good ten minutes.
You could also play some Paramount + content on a Smart TV app.
This seems to do some kind of account link refresh and after doing this your Sky box should play fine again.
This message was authored by: Samsonjh
Paramount+ stalling and failing constantly
Every time I view Paramount+ it stalls and then fails, normally during adverts, and then has to restart as if buffering problems. It's not signal strength because every other platform works fine. Is anyone else having this?
Re: Paramount+ stalling and failing constantly
@Samsonjh
On what device are you using to view Paramount+, so Sky Q, Glass, stream, tablet, PC etc....
Sky Q via a Samsung Smart TV
This message was authored by: Nmac2
Paramount freezing in Sky stream
Watching Paramount plus, every 20mins it freezes. I have to close and restart, it stops starts
This message was authored by: Greenfingers001
Re: Paramount freezing in Sky stream
This message was authored by: Sashagigidax
Paramount + freezing
The paramount + keeps freezing and we can't get through an episode of any show on paramount
Re: Paramount + freezing
Moved your post to this ongoing discussion thread on changes recently to P+ app.
A number of customers are suffering from this.
Is it halting for you when an advert is counting down or at other stages during your viewing.
If you can describe further it will help Sky and others to compare the fault.
  • Yes. It freezes when the ads come on, the  ads will run for 15/20 secs then freeze , then we try to reset and error code 3005 comes up , I have checked all connections and the signal strengths they are all fine.
  • Hope this helps
This message was authored by: MatWolfman
So frustrating, having the same issue. Have to come off the tv, watch the adverts on my phone and then back on the tv. Freezes everytime on the adverts with error code 3005 or 9999. Router is in room and no issues with WiFi
This message was authored by: DebbieG172
Paramount + error code 3005
I have Paramount + available and am able to load it ok and watch the programme but as soon as I get a 90 minute advert it will freeze periodically during it, then freeze and throw me out. I get an error message that says ooopps you appear to have a problem with your internet connection. Error code 3005. It plays the programmes fine and only freezes during the long advertisements. Sometimes it will continue after the freeze only to freeze again some seconds later and then throw me out.
I did not have this issue in the past with it (just only aware in the last few weeks when I tried to  rewatch 1924 season 1  in preparation for the new release of season 2)
It does this on my main box and my mini box. I have rebooted both ( switched off, unplugged and waited etc...) I have updated for any system changes on both boxes.
I have no streaming issues with any other App such as Netflix, Amazon prime, Disney + , Discovery + and don't notice any issues generally with my internet.
This message was authored by: Mr+Flibbles+86
Re: Paramount + error code 3005
This message was authored by: Kim1108
I have the exact same problem. Did you get a fix for it ?
Locked
