1596
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: Trechs
Re: When watching programmes on Sky Stream the sound is out of sync with the picture.
All it has proved, is that we're not getting a service we're paying for.
This message was authored by: WarrenBoz
I suspect the issue is buffering. Your TV and Apple tv box have a memory to enable them to buffer a small amount of data before playback. The puck doesn't and is a direct link to the servers, so if there is any form of issue with the stream then sync issues occur. Fundamental issue with the Puck I suspect.
This message was authored by: Johnny811
I've had Sky Stream for a few months now and experience some lip sync issues. Many on BBC ONE  live and some free view channels. I find changing channel and then tuning back improves it but it can still be out a little.
I've tried PCM Stereo which has fixed this but should I be using Passthrough? Which gives the best quality as I have a soundbar?
When selecting Passthrough a message came up stating "As you have selected passthrough, you will be unable to hear any system sounds and voice guidance" I'm not sure what this means?
Cheers,
John.
This message was authored by: koopie
It means that any sounds which your TV produces like beeps and similar noises when you are in Setttings and you change a configuration item, say in Picture Mode and you change from Standard to Cinema or as you move around Settings from one menu to another, say Picture to Sound.
Passthrough is the correct option if you are using an external speaker /sound system as it effectively switches off TV sound.
This message was authored by: BC1956
I'm sorry John I'm not a techie I can't answer this
Sky FF Gigafast / Sky WiFi Max / Sky Stream / 2 Pucks / Sky Ultimate TV / Sky Sports / Sky Cinema / Sky Whole Home / Sky Ad Skipping
This message was authored by: Si99
Hi all
only think that worked for me was
set to pass through.
connecting the sky puck to the soundbar then hdmi out from soundbar to tv.
Not sure what is best if your soundbar only has one hdmi port.
i did also get a ugreen hdmi cable with latest standards  to go from soundbar to tv which may have helped.
I only have one socket in my SB but I am just interested...... what is the picture like after being passed through the SB? It seems  really odd thing to have to do
Re: When will the Sound Sync issue be resolved?
Hi I am new to Sky and have had this issue from the start I have tried all the different settings, I have looked back at various discussions to do with sound lip sync has been a long term issue and has never been fixed the amount of members that are complaining about this on community is unbelievable
There should be no change in the picture.
Thanks for the reply's. I'll keep mine on Passthrough and see how it goes for now. Wonder when Sky are going to fix this bug, then it can go back on auto I guess.
Don't hold your breath on getting Sky to fix this any time soon. The issue began with Sky Q and ARC and has been carried over into Sky Stream. It's been an issue at least since 2016 when I got my first ARC tv.
Ok cheers. So just to confirm you think Passthrough is the better option than PCM stereo if I'm using a soundbar?
This message was authored by: Veii
I get it really bad on Animal Planet but not other channels. It has been doing it since I got Sky Stream on November 7 and is still doing it weeks later. I haven't noticed it on any other channels, not even other Discovery owned channels, it just seems to be the Animal Planet channel. I don't use Dolby Atmos or soundbars so it is set to Stereo and it gets restarted all the time when I unplug it to take it upstairs or downstairs depending on where I'm watching it.
Jonny, yes.
This message was authored by: Paul+Dray
It's actually more in line with how a higher end AV system works. I.e.  Connect all devices to the AV Amp/Receiver which in this case is represented by the Soundbar and then hdmi out to TV/display panel. A daisy chain if you will.
As an aside I've seen some here say their Soundbar only has one hdmi in. To be accurate if it only has one hdmi port that's an hdmi OUT (to tv) not an hdmi IN port. You could say that's me being fussy but actually it's helpful to think of it that way to understand the process for yourself. It also helps confusion for techies as they could think that saying that there is 1 hdmi in to mean that this is in addition to the hdmi out port.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS037.045.01P | Sky Broadband Superfast
Locked
Answered - Go to Answer
