Discussion topic: Lip Sync issues - Sky Stream
Message posted on 26 Nov 2024 05:51 PM
@BC1956 wrote:Hi thank you for your quick response. Unfortunately the soundbar only has 1 hdmi socket, there is an in but no out
Yeah sorry I've just seen that now. Thought the spec page said one hdmi in as well as hdmi (ARC) out but looking at the manual as you say it doesn't. They really minimise the connections on these soundbars now compared to what they used to.
so yeah sorry scratch that idea for your particular setup.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS040.024.00P; UI Version: 3.204.1 | Sky Broadband Superfast
Message posted on 26 Nov 2024 06:36 PM
Thank you, you tried mate👍
Message posted on 27 Nov 2024 01:16 PM
Re: When watching programmes on Sky Stream the sound is out of sync with the picture.
Hi, thanks for this. Looking through here it does seem there is an issue although i have only experienced no synch issues within the last few weeks. Strange there is a setting to "adjust" the synch in milliseconds, seems a bit hit & miss. PCM is much better but its not quite there but very close, thanks anyhow.
Message posted on 28 Nov 2024 06:18 PM
For me its working ok now, now I have my broadband up and running, it was doing it because I was using my 4G on my mobile phone, its not that great with it.
And I have connected SKY Steam Puck to my SKY Hub by a RJ45 cable, its faster so no lag now, thats how I connected my SKY Q box too.... 🙂
All I wish now is that SKY Stream had the same interface as Sky Q, I still think it the best and easiest GUI to use, I had it for about 5 years, before that SKY+HD, I only using SKY Straem because my building is not compatable with it, but I am happy with SKY Stream, I like better then NOW.
Thanks for all your help SKY and especally what I am going through ATM, my partner died and she was the SKY account holder so every had to be change it into my name .. 🙂 , SKY were great about it and helped me alot.
I am not a Sky Engineer but at one time wanted to be one or a BT Engineer... 🙂
I like working things out like its a puzzle... 🙂
I was a PC Engineer and fix peoples PCs by going to there house, Windows XP was known to slow down PCs over time and clog up the PCs RAM and its start-up and had to reinstall it for the customer.
Sky Glass Air 55 inch.
Message posted on 29 Nov 2024 04:29 PM
This is what I do at the moment and it works
Message posted on 29 Nov 2024 10:10 PM
I have serious lip sync issues on all channels, very annoying. I am seriously thinking about cancelling my contract as the service is not being supplied as promised. Can anyone from Sky help please?
Message posted on 30 Nov 2024 08:11 AM
@kweyman you won't get a response from Sky on here they obviously don't monitor their Sky Community
Message posted on 30 Nov 2024 01:59 PM
I've started getting an additional lip sync issue (on top of not being able to use anything other than PCM to get in-sync audio) and that is channels either starting or going out of sync by several seconds.
Literally as I was typing this I had it happen. I switched to Sky Sports F1 UHD a while ago and the audio was out of sync, I changed to another channel and back and sound went back in sync. However, when the program switched to an ad break it there was a noticeable skip in the audio and it went out of sync again. Specifically the ad was Idris Elba selling some AI nonsense. I mention it because it was during that same ad yesterday that I first noticed the issue so I'm not sure if it's the ad, or the switch from live programme to ad break that's causing it but there seems to be some connection.
Just to note this is happening on both HDMI eArc and optical with audio set to PCM and the puck is on the latest update QS033 (which I suspect is the cause as it only started in the last day or two)
Message posted on 30 Nov 2024 04:07 PM
I've got that too. I haven't spent the time (and patience!) trying to figure out the trigger, but it seems to affect all ' live' channels. Added to this I am experiencing frequent interruptions particularly if I have used 'pause' when watching live tv. Beginning to wonder if my puck is dying. Hope so - I'd love to perform a ceremonial cremation!!
Message posted on 01 Dec 2024 03:13 PM
When will the Sound Sync issue be resolved?
We have Three pucks, and each of them has the same problem
Sound Sync, on most channels and at random
Turn off, leave and turn back on and cross fingers.
Tried different sound modes, different sound delays.
Problems is on all and a continuous problem
Watch Netflix, discovery+ etc, NO problems at all, just live TV
Getting fed up with it now
It isnt our Broadband we have 330meg download, and tried different wifi bandwidths, makes no difference.
See it is a SKY puck problem
Any further help aprreciated
Message posted on 01 Dec 2024 03:29 PM
Sound massively out of sync today on Sky sports F1 UHD, probably out by about 3 seconds!! Pretty much unwatchable
Message posted on 01 Dec 2024 04:39 PM
Re: When will the Sound Sync issue be resolved?
@DonnaJ The previous lip sync issue was resolved but unfortunately this appears to be a new issue which started only recently. I am aware that Sky know of the issue so will be looking for a solution to fix it.
Message posted on 01 Dec 2024 06:20 PM
I am getting this issue all the time with the Sports channels atm, and it's p****** me off. If I change the channel, then change back again, the sound and picture are synced, but it doesn't take long for the sound to get way ahead of the picture again. I'm using Sky Glass.
Message posted on 01 Dec 2024 06:35 PM
the sound drop outs continue
well after a few days of things being 'back to normal' it's started again today with a vengeance - i'm going to ring sky tomorrow and ask to cancel as i've had enough - paramount needed a restart to get it off a black screen today as it crashed the puck - sound has gone off 10x easily today nothing sorts it - is anyone else going through this? if it's just me it's hard to say it's not fit for purpose
Message posted on 01 Dec 2024 09:49 PM
Suffering from this big time and nothing (settings change) resolves it. Watching NFL now - started out ok but went Dalek with no warning. Seems to be random, but bizarrely even ads have lip sync issues. Anyone had that? Shocking from Sky. Price hikes galore and quality plummets. I'd cancel right now if I could but still have a year to run on contract.. Can't recommend Sky Glass to anyone. Still way too buggy.
