1516
This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
This message was authored by: Freddie1960
The sound on tv does not work properly since i changed to stream from dish
The sound on my tv does not work properly since i changed to streaming
This message was authored by: Padam_Padam
Re: The sound on tv does not work properly since i changed to stream from dish
In what way does it not work? Are you not getting any audio? Are voices out of sync?
This message was authored by: Peter682
Re: QS025 Lip Sync Issues
Hi for anyone with lip sync issues,it is an ongoing problem sky is trying to fix,in the meantime go to settings,then sound settings and change from auto to PCM STEREO,I did this right back around 6 weeks ago and had no more issues with syncing sound with picture,works fine...oh,no soundbar etc,smart tv..
@Peter682 @The issue is this has been going for months. Switching to PCM and effectively losing surround sound and Dolby Atmos isn't really a fix, it's a reduction in service, whilst Sky are still charging a premium for Dolby Atmos to most customers
@Anonymous  I don't think there was a specific fix in the latest QS028 software update but I have not had any lip sync issues since I received the update.  I have now reverted my audio setting back to auto.
If my post has solved your issue please mark as an "Answer"
@Fothergill1 @Let's wait and see until everyone has the new software and take stock. I am a huge fan of Sky and stream but do find it hard to swallow that this lip sync issue hasn't been resolved for many months. We aren't talking about a minor issue here. Especially as it's a paid extra service for Dolby Atmos and the 'fix' means losing this.
It sounds like the people on tv are talking under water
@Freddie1960  I have heard of this underwater description before so did a search and came up with the following thread.  I have not read it but it may contain something of relevance to your issue..
@Anonymous re your post 303, I fully agree.
This message was authored by: Alip14
Sound out of sync when using a puck
We are using a puck.  Recently we are getting problems with the picture and sound being out of sync with each other.  I've reset the puck, it's up to date but nothing works.  I. Assuming that there is a problem with the puck.
Re: Sound out of sync when using a puck
This is a long standing issue with the Stream puck. Change your audio output to PCM Stereo or passthrough - this should help until Sky push out a software update.
This message was authored by: Deedee36
@Alip14  This is a known issues which sky are aware of and are working on a fix,in the mean time a workaround is to set the sound out to pcm
“Trying to help improve sky glass”
This message was authored by: Paul+Dray
I just looked at this thread you linked to out of curiosity. Is this something that only happens on sky glass then? Weird behaviour. Its like the main dialogue channel which would be the center speaker in a seperate speaker setup is switching off and the muffled sound is just the residual 5 - 10% off dialogue sound that gets fed to the L & R channels.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS035.016.00P | Sky Broadband Superfast
Indeed. There have been quite a few reports of this happening following the failure of the centre speaker on Sky Glass.
Sadly. Sky Glass is a very average tv in terms of build quality and components.  It's cost is probably double what it would be if purchased on a like for like features basis with another manufacturer.
This message was authored by: Jonathanphillip
I'm finding pass through a lot better but putting it on pcm stereo doesn't work passthrough does work
Answered - Go to Answer
