1593
This discussion topic is read only This discussion topic has been answered Discussion topic: Lip Sync issues - Sky Stream
Locked
This message was authored by: David190512
Re: QS025 Lip Sync Issues
Have used Sky Stream for over a year, zero issues with my 3 pucks.  Since ast week all 3 suffering lip sync issues. Have tried Passthrough and PCM with limited success.  Have 1gb fibre broadband so that's not the issue.
clearly some port of update rolled out which hasn't been properly tested.
This message was authored by: Paul+Dray
Noticed today the Settings page has been revamped. Is this part of the new Entertainment OS 1.3 features being added or to do with an update to the UI version 20.285.028.06? I suspect the later.
Pioneer Kuro PDP-LX5090 50in Plasma TV | Yamaha DSP-AX863 SE AV Amp
Sky Stream Puck; Build: QS037.045.01P | Sky Broadband Superfast
UI version update change.
Had an update at some point in the last few days (to 508). Tried setting Souond to Auto today... still way out.  Whatever fix was meant to be in there obviously does not work.
This message was authored by: CPoin
Update landed on my puck this morning. Plugged the Sonos Beam back into the TV by HDMI, switched the puck back to passthrough and it's working fine so far. Some annoying crackling whenever changing streams but lip sync is spot on now.
This message was authored by: Matt+Nunns
Mine seems good now as well with latest update, big delay between turning it on and audio coming out, but can live with that, can now rewind/pause and still have audio!
This message was authored by: Super+Anthony
Am still on 1.2. Hopefully soon
(Please Note: I am Neurodivergent )
What about lip sync when you choose the other audio output options other than passthrough & PCM? As this is where most people have been having troubles.
UI update has landed on one of 3 boxes and does seem better
Still for me QS027 and UI 20.284
This message was authored by: Mand
The timing between sound and vision on tv is wrong
When tv sound is playing it does not match the lips being spoken by people on tv
Re: The timing between sound and vision on tv is wrong
@Mand  Welcome to the forum. This is a very long thread so to save you having to wade through it; this is a known issue which Sky are trying to resolve.  They advise that as a temporary workaround you change your audio settings to PCM or Passthrough.
There is currently an update (QS028) bring rolled out and whilst there is not a specific fix for the lip sync issue I have found it resolved the problem on my setup.  However, other subscribers have not been so lucky.
This message was authored by: DaveH765
Lip sync sky puck uk
  • Anyone having problems with lip sync, ive tried everything sky suggest and it doesn't work, if I watch BBC it's fine, as soon as I move to other channels like Discovery HD it's out by a country mile, getting very frustrated now. I'm using high speed hdmi to bose 900 soundbar.
Cheers.
This message was authored by: Jporch316
Re: Lip sync sky puck uk
Cheers.
there is a thread on the sky stream forum specifically for this issue although I'm not sure it affects sky glass. I have a feeling this is more to do with your setup using a soundbar.
In the settings there is a section for adjusting the sound delay which you could use to re sync your sound. I am assuming that without the soundbar the sound is fine.
you should also plug the soundbar into hdmi 2 which is the E arc hdmi socket
Ah .... I have just re read your post .... you have a sky puck. This is the sky glass forum
@GD1  can you merge with the main thread in the stream forum
@DaveH765
things a known issue that seemed to be fixed in the firmware update .... not all devices have received the update as yet
you can try changing the setting in the audio settings to pass through which should give you a temporary fix
Locked
Answered - Go to Answer
