This discussion topic has been answered Discussion topic: Is it possible to get program reminders on sky stream puck?
Message posted on 28 Nov 2025 03:51 PM
You'll be happy to learn that you can now set reminders on Sky Glass or Stream.
Here's the link to read about it and for some help setting them up 🙂
Kev
Community Manager
Message posted on 01 Oct 2026 12:08 AM
Re: Is it possible to get program reminders on sky stream puck?
Not on mine it isn'r
That's not true
Message posted on 01 Oct 2026 08:25 AM
It is possible. Reboot and it should appear.
Message posted on 01 Oct 2026 08:29 AM
I found out that updating the puck's system has now solved that thanks....took ne about an hour on the internet searching to find that out though
Message posted on 02 Oct 2026 10:35 PM
Having said that I've now got programme reminders working, it's still not that great because as far as i can tell even if you have a series on your Watch list and you set a reminder for an episode, the next time it's on you have to set the reminder again, so it doesn't work like the Series Link on the HD+ Box, so it's not much better than not having it all.....or am i missing something?
