This discussion topic has been answered Discussion topic: Is it possible to get program reminders on sky stream puck?
Message posted on 28 Nov 2025 03:51 PM
You'll be happy to learn that you can now set reminders on Sky Glass or Stream.
Here's the link to read about it and for some help setting them up 🙂
Kev
Community Manager
Message posted on 01 Oct 2026 12:08 AM
Re: Is it possible to get program reminders on sky stream puck?
Not on mine it isn'r
That's not true
Message posted on 01 Oct 2026 08:25 AM
It is possible. Reboot and it should appear.
Message posted on 01 Oct 2026 08:29 AM
I found out that updating the puck's system has now solved that thanks....took ne about an hour on the internet searching to find that out though
