183
This discussion topic is read only This discussion topic has been answered Discussion topic: HAYU Application continues to not work
Locked
This message was authored by: KHC1
Re: HAYU Application continues to not work
HAYU told me to turn sky box off and on again
This message was authored by: PatriciaNC
Hahaha hopefully all will be fine in the world of Reality TV now 😄
This message was authored by: jsnbts
Ah, the old turning it on and off trick.. As if nobody has tried that already.. 🙄
Anyway, somewhat miraculously the HayU app on Stream now seems to be working again for me, at least on one of my pucks. Not because of turning it on and off though - I tried that many, many times over the past few weeks alongside refreshing the apps too and nothing made it work.
Clearly whatever the bug was that was causing this seems to have now been sorted.
I sometimes see people on here claim the apps don't run on the pucks but instead run on servers at Sky's end. If that's the case why do apps sometimes work on on one puck but not another, or start working after a reboot.
This message was authored by: JaneMH19
Hi, mine isn't working either.  So frustrating ,  just another issue that Sky claim to be working on.
Hi, mine isn't working either. Appears to be yet another issue.
Same here, there's broken sound but just a blank screen.
This message was authored by: gembers
Mine is now working. I reset the apps and worked straight away.
Mine is giving a blank screen when I press the down arrow. I have been advised by Sky to keep an eye on this thread for updates. It is working better than what it was but still not what it should be.
This message was authored by: Sym
Hayu app
Started having issues with my sky glass it won't let me upload the Hayu app that I pay a subscription for
have reset TV
have reset internet
have gone into settings to refresh apps all updated but still not working to watch any programmes on Hayu!
Has anyone else had this issue & any suggestions? Thank you
This message was authored by: EmmaEllis
Is there any update on when the Hayu app will start working on Sky?
Hi, yes my Hayu works perfectly through Amazon but not with the Sky app.
Great thanks I will try that way
Hi, I think you need to subscribe through Amazon to watch it on there, I'm have one month left of it as changed to going through Hayu with their January offer and logged in via the app on Sky which isn't working.  Hope this explains my previous message and avoids confussion .
Yes that makes sense. I just tried to log in via Amazon and realised that you have to subscribe through that. I'm still on the 7day free trial so I can cancel that and subscribe through Amazon. Thanks for your help
Locked
Answered - Go to Answer
