Discussion topic: skyway mini box
This message was authored by: catering
skyway mini box
i have tried for 2 days to connect my mini box to my internet and main box still not connecting it is a new box the 2nd 1 and now i'm fed up thinking of ditching sky q tv ..,, i want an engineer out but no luck of getting one ,,,
Avatar for catering
Re: skyway mini box
i have tried every possible thing going i just want someone to come out ?? or i'm going to find another provider ..,,, sky has a lot of complaints
Re: skyway mini box
Hi @catering
To connect the main Q box.
If you get your main Q box connected then next reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Avatar for catering
Re: skyway mini box
hi skyway
yes i did that still wouldn't connect seriously i have absolutely tried everything and why should we go through this stress  it's not fair .... but thank you for your reply .....
Re: skyway mini box
What broadband provider? If Sky, which router have you got?
Avatar for catering
sky mini box
i'm now looking at a new broad band provider because it is impossible to get an engineer out to set up
Avatar for catering
Re: skyway mini box
sky  Q and mini box
Avatar for catering
Re: skyway mini box
i want an engineer out but trying to get one is impossible ??
Re: skyway mini box
Yeah you said
I think you have to go through all the troubleshooting with Sky on the phone and then if they can't fix it remotely their last resort will be to send an engineer.
