Discussion topic: faulty mini box
This message was authored by: citygirl32
faulty mini box
how can i get a replacement for a sky mini q box it keeps droping out saying no connection so we have to turn it on and off and reset it all the time
Re: faulty mini box
@citygirl32 first thing to try is rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for citygirl32
Re: faulty mini box
hi done this several times no joy just need to find out how to get a replacement
Re: faulty mini box
@citygirl32  If it's losing connection to the main Q box then it's likely a new mini won't cure the initial issue which seems to be wifi related.
Re: faulty mini box
Hi @citygirl32
Try another Network Reset on the mini.
