Discussion topic: faulty mini box
Message posted on 19 Feb 2025 06:29 PM
faulty mini box
how can i get a replacement for a sky mini q box it keeps droping out saying no connection so we have to turn it on and off and reset it all the time
Message posted on 19 Feb 2025 06:35 PM
Re: faulty mini box
@citygirl32 first thing to try is rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Feb 2025 08:38 PM
Re: faulty mini box
hi done this several times no joy just need to find out how to get a replacement
Message posted on 19 Feb 2025 08:49 PM
Re: faulty mini box
@citygirl32 If it's losing connection to the main Q box then it's likely a new mini won't cure the initial issue which seems to be wifi related.
Message posted on 19 Feb 2025 08:52 PM
Re: faulty mini box
Hi @citygirl32
Try another Network Reset on the mini.
