Discussion topic: Sky Q saying card not active
This message was authored by: Sandra119
Sky box won't turn on I've rebooted it reset it now the remote won't work!!
Re: Sky Q saying card not active
Hi @Sandra119
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
