2
This discussion topic has been answered Discussion topic: WiFi connection
This message was authored by: Ian2968
WiFi connection
My sky Q box has suddenly disconnected from the WiFi now it won't connect either using WPS or password
This message was authored by: Quoman7 Answer
Re: WiFi connection
Hi @Ian2968 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
Re: WiFi connection
Avatar for Ian2968
Re: WiFi connection
Hi @Quoman7  this worked thanks for the help 👍
