3
This discussion topic has been answered Discussion topic: Sky box in bedroom says no signal and can not connect to your network
This message was authored by: Tracey16
Sky box in bedroom keeps saying no signal and can not connect to the network
Avatar for Tracey16
This message was authored by: Tracey16 Answer
Re: Sky box in bedroom says no signal and can not connect to your network
Thank you oldfella we have tried all that but thank you for your responce but still nothing so iv got sky coming out x
Hi @Tracey16
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Avatar for Tracey16
Let us know how it goes. Suspect they will install a Booster.
